pause when starting
Old Oct 20, 2025 | 09:10 AM
TR860's Avatar
TR860 will become famous soon enough
Default pause when starting
Hi guys and gals, been awhile since i have been here. Anyway lately when i start my vehicle (98LS, 4.3, 4WD, 123,000 miles) it will crank 2 or 3 times then theres a bump where i lose power (radio/clock go off, dash lights go out) for a split second then cranks normal. Thinking maybe starter or ignition switch. Any ideas? Thanks Tom
Old Oct 23, 2025 | 10:14 AM
GeorgeLG's Avatar
Make sure that the battery cables are clean and tight as well as the battery ground. Have the battery load tested. If you still have the problem then pull the crank fuse and go through the ignition switch motions a bunch of times. If you still have theproblem it depends on how fancy you want to get Either get a probe on one of the power inlet wires to the ignition switch to see if power stays stable there to formally indict the ignition switch or go straight for an ignition switch replacement which would be a good educated guess. If the crank fuse experiment fixes the problem, have the starter tested.
George
Old Oct 23, 2025 | 11:23 AM
TR860's Avatar
havent had time to check things out yet, where do i find the crank fuse?..Thanks for the reply, will check everything out when i have the time...Thanks again.
Old Oct 23, 2025 | 11:56 AM
GeorgeLG's Avatar
From your owners manual:
George
Old Oct 23, 2025 | 12:23 PM
TR860's Avatar
Thanks pard
cosmodrome
Jul 7, 2016 09:17 PM
princered72
Jan 14, 2015 06:27 AM
drenski
Nov 16, 2008 01:31 PM
Ethel
Nov 2, 2008 10:03 PM
sleonh
Aug 26, 2006 11:03 PM
