Prenvenative Maintenance - a/c issues
My '03 has a slight hesitation in first gear between 1500 - 2000 rpm. I have done the following;
Replaced Spark Plugs
Replaced Fuel Filter
Clean MAF Sensor
Check Spark Plug Wires, look to be good, Blazer only has 70K on it
I bought in 2010 with 56K on it and the intake gasket had already been replaced.
The hesitation is minimal but I have learned from owning 3 S series Chevys that preventive maintenance is better.
I have not check the fuel pressure, could be that fuel pumps is heading the wrong direction?
Thanks in advance for your thoughts!
*Anyone the best way to get to the a/c condenser?
I am Looking for leak! The dye I injected is only showing around the
accumulator. This could be here from my efforts to inject the dye.
Clean MAF Sensor
Have you looked at the cap and rotor for signs of corrosion? A fuel pressure and leakdown test wouldn't hurt, you can rent a gauge from autozone, leave a deposit and get your money back when finished. It should be about 60 and not leakdown for 10 minutes with the key on, engine off!
An alternate method for finding a leak is to use soapy water and check for bubbles, unless you know someone with an electronic sniffer.
chipjumper
15
Dec 14, 2019 08:49 AM
