Question
My buddy & I did a oil change on my truck and he said it looks like I am going to need to get the end links for the sway bar. I'm not too sure what he was talking about. Any ideas. How much a Front Sway Bar for a 2001 4dr blazer goes for?
Energy suspension endlink kits are dirt cheap! Under $20 for both sides for poly bushings. Easy to change out too. I don't even remember jacking up the front of the truck to do it.. Just turned the wheels to the right and replaced the right side, then back to the left to replace the left side.
EnergySuspension.com for the part numbers. They used to be available at Advanced Auto, but I don't see them on their website anymore. I believe it was 3-5206 for the 28mm sway bar bushing set (which includes the sway bar to body mount bushings) and 3-5207 for the 33mm sway bar set.
Pretty much any poly set will last longer than stock.
ORIGINAL: swartlkk
...I believe it was 3-5206 for the 28mm sway bar bushing set (which includes the sway bar to body mount bushings) and 3-5207 for the 33mm sway bar set.
