question about a blazer conversion from 4.3 to a 350
Old Dec 16, 2009 | 08:29 PM
Calvin McLaughlin's Avatar
Calvin McLaughlin is on a distinguished road
Default question about a blazer conversion from 4.3 to a 350
what might i need to make a swap to 350 or 327 carb and can i still use my same trans this is on 2000 s10 blazer 4x4 4door
Old Dec 16, 2009 | 11:34 PM
NVANZEE's Avatar
you can use the same trans. You will need motor mounts, headers from JTR, if you go fuel injected you will need the computer and wiring from doner vehicle. You have to convert to electric fans and a few other things im forgetting. Try doing a search for it. I know it has been discussed a few times. Check you Jags That Run. They have a kit that includes a few of the things you will need along with a manual.
Old Dec 17, 2009 | 12:33 AM
TFisher's Avatar
Banned
TFisher is on a distinguished road
If you want a carb (as in carburetor), you will have to remove the engine computer and replace it with a dedicated transmission computer. Then, you will no longer have OBD-II, none of the sensors, and you will have quite a difficult time getting the electronic systems to play nice -- as in your cruise control will do nothing, you won't be able to have a check engine light etc. It would be much easier (and road legal) to put a 5.7 in it. For that all you need to do is get the engine, trans and computer out of a tahoe, preferably the same year as your Blazer, but any after '96 with a mechanical accelerator pedal will work (I think). Hope this helps!
Regards,
Thomas
Old Dec 17, 2009 | 06:45 AM
thanks for the info it will help out alot thanks again
Bobcat13
Nov 10, 2013 06:03 PM
tech180
Feb 2, 2013 10:23 AM
syxpack
Jan 10, 2009 07:46 AM
redlineracerjpcb
Performance & Brainstorming
Jan 31, 2008 07:21 PM
2kSnakeEater
May 30, 2006 08:34 PM
