Question About 4x4
Old Dec 15, 2009 | 04:04 PM
yones12's Avatar
yones12 is on a distinguished road
Default Question About 4x4
I have a 1995 Jimmy/Blazer. I have Push button 4x4. And i was wondering can i shift it into 4x4 when im driving or do i have to stop because i have shifted it in 4x4 when driving but i dont want to mess anything up
Thanks for looking
Old Dec 15, 2009 | 04:06 PM
Sisk's Avatar
I wouldn't continue doing it. It's always a good idea to stop and shift into neutral before switching into 4hi or 4lo. That way you don't run the risk of trashing your transfer case.
Old Dec 15, 2009 | 04:08 PM
yones12's Avatar
Ok thanks, unless im already driving and slipping then i will just press the 4x4 button
Old Dec 16, 2009 | 07:38 PM
bulwaagh's Avatar
bulwaagh is on a distinguished road
erm, my manual said that I could shift into 4w hi @ "any" speed. My parent's '89 would allow the same behavior. 4w-lo was a stop and neutral shift, though (Manual says "neutral at under 3mph").
Old Dec 16, 2009 | 08:42 PM
ABN31B's Avatar
@ Calvin: what? what does have to do with 4wd on the fly?
@ yones12: it's shift-on-the-fly. i wouldn't do it at 85 MPH with my foot in the gas, BUT, you are fully able to shift into 4hi at a reasonable speed. This is the main reason i dislike anything but manual shift levers. anyway, i have gone into 4hi as fast as 35 mph. i wouldn't try any faster than that, AND i only did it out of need. if it could be helped i prefer to slow down a LOT more than that.
it's probably bad for it in the long run, but you can do it.
Old Dec 17, 2009 | 07:54 AM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
I have asked this question as well when wondering at what speed to shift into 4Hi. So I got out the 1996 Chevrolet Blazer Owner's Manual and had a look. And shifting from 2Hi to 4Hi I quote " Press and release 4Hi Switch. This can be done at any speed, and the front axle will lock automatically"
I wouldn't recommend doing this at high speeds. Although I have put mine in 4Hi at 45Mph a few times.
When putting my Blazer in 4Lo I always stop put it in Neutral and then shift to 4Lo. On my Sonoma which has a 5spd you have to stop put it in Neutral and push the clutch all the way to the floor before it will go into 4Lo.
Athlon2012
Dec 16, 2014 11:35 PM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
