Quick question
Without the lights on & I apply the brake the left tail lights up.
When I have my park lights on & I apply the brakes, both tail & stop go out. (left side only)
What's gone wrong? Fuses are all ok.
Were you tinkering with the bulbs at all? If you changed em you may just have to turn the bulb around the opposite way you installed them.
Never mind that plan. I misread.
Ya looks like an electrical problem, and I can't help ya there. Sorry!!
Do you have the normal US spec tail lamps or the Euro spec?
Euro specs. The lenses only house 3 bulbs. The 4th (rear fogs) I've tucked away behind the unit - with the bulbs still in. Been like this since I fitted them & have always worked till now.
I had the same problem with mine and went through a flooded road last fall and now it has worked fine! I know this doesnt help you with your problem. I went to tow my trailer and the trailer lights wont work. Turn signals and brakes do. Replaced the fuse under the hood and they worked for about 10 minutes on the road then the fuse blows. Cant find a short anywhere through the wiring. Who knows.
