Replacing the fuel pump and tank in the morning...
Old Nov 7, 2009 | 08:22 PM
degaine_designs's Avatar
degaine_designs is on a distinguished road
Default Replacing the fuel pump and tank in the morning...
I think I mentioned a while back that the fuel tank was leaking pretty bad. I got a 20 gallon plastic tank off of eBay and I figured I might as well replace the pump as well so I got a fuel pump from LMC Truck.
Both parts have been sitting in my house for a couple weeks now while I've tried to find time and a day with good weather to switch 'em.
I've never replaced the pump before, is it difficult? I have a Haynes manual so it shouldn't be too difficult, hopefully. I should probably change the filter to. I guess I'll check it tomorrow and if it needs to be changed I'll do so.
This is going to be interesting. I'll try to get pics.
Old Nov 7, 2009 | 11:16 PM
foxxie's Avatar
Hope everything runs smoothly for ya.
Old Nov 8, 2009 | 01:22 AM
Thanks, me too. :P
EDIT: Well, I got it all installed and nothing blew up! It started right up when I was finished. I'll have to go fill up the tank tomorrow for the first time since I bought the truck. Pics coming.
Old Nov 9, 2009 | 12:09 AM
foxxie's Avatar
SWEET!! a job well done, how long did it take ya?
Old Nov 9, 2009 | 03:17 PM
It took about seven hours. The old tank just didn't want to come out. Most of the bolts were rusted and I couldn't get enough leverage to really crank on them but with the help of a piece of pipe just the right length, I was finally able to get 'em loose.
Here's some pics. The close up of the tank shows one of the holes. There ended up being at least two holes, both pin sized. I couldn't believe that they could leak so much.
Attached Thumbnails Replacing the fuel pump and tank in the morning...-16242_1291582208959_1212373859_1567745_2002225_n.jpg   Replacing the fuel pump and tank in the morning...-16242_1291583048980_1212373859_1567748_7967841_n.jpg   Replacing the fuel pump and tank in the morning...-16242_1291580848925_1212373859_1567744_8318755_n.jpg
Old Nov 10, 2009 | 01:00 AM
foxxie's Avatar
Wow! the old tank was pretty f**ked, at least you wont have that problem again with the plastic tank. Always found a can of WD40 handy for problem bolts like that.
Old Nov 10, 2009 | 01:58 AM
Tried WD40, it helped... a little.
Old Nov 11, 2009 | 04:18 PM
seanstutts's Avatar
seanstutts is on a distinguished road
i replaced my fuel pump while back no problem gettin tank or pump out but on my 97 the whole pump is spring loaded and has a heck of a O-ring thats almost impossible to get the pump to go back in evenly or in at all.tried to lube it up with a little PB then oil and finally got it in but it only took bought an hour or so out and in.
Terje
Nov 4, 2017 08:19 AM
wjdjake
Jul 17, 2011 02:06 AM
ericshaw
May 31, 2011 08:50 PM
Nick_K5_Blazer
Jan 18, 2011 06:35 PM
cide
Nov 7, 2009 01:26 PM
