rocker panel dent what should i do .......?
the title says it you don't see it the door dings from the ignorante ubanite ****** stick out more but it still bugs me how would a body shop fix it ?
I really can't see how they would get behind it . Bondo ? not for me < drill holes? eek
the other thing is my year old KCs driving lamps are starting to rust suggestions ?
I was thinking a bead blasting and armour /gun kote is in order.
the other thing regardless of the undercoating I am starting to see surface rust at 2 years
opinions , suggestions
thanks all
thanks all
For the dent, a stud gun would probably be my first choice. Weld the studs on and pull the dent out. Then just grind them off when finished. If they cannot get to the back side, there will be some filler needed for a good repair.
ESKYMOPACK
22
Dec 24, 2010 11:47 PM
bigdaddykane93
Dec 22, 2009 12:29 PM
bigdaddykane93
Dec 22, 2009 12:03 PM
