Rough accel, please help
Old Dec 8, 2022 | 08:05 PM
Juggalonmd's Avatar
Juggalonmd is on a distinguished road
Default Rough accel, please help
Hello all!! Hippy holidaze!! I'm in an 89 S10 blazer 4.3 2wd. runs really rough when 8n gear and I give some throttle. Only runs good with injector cleaner I'm the gas tank. I've even tried some heet in the gas tank Recently I've changed the tps, maps sensor, temp control sensor, fuel pump, fuel filter and plugs. I even had to rebuild throttle body to clean injectors. And still having issues getting it to run right. When I give some throttle in gear it spitter sputters as it accelerates and continues when driving. I've checked timing to. Can anyone give me some help please. I'm getting ready to go over a pass here in Washington for the holidaze next week and need my rig running right. Any input will be greatly appreciated.
Keep moving forward
Hippy holidaze and hippy new year
Old Dec 9, 2022 | 02:16 PM
GeorgeLG's Avatar
It runs better after you run a bottle of injector cleaner through the tank or it only runs good when injector cleaner is in the tank? How much are you adding to how much gas?
George
Old Dec 11, 2022 | 12:23 AM
Juggalonmd's Avatar
it runs fine with cleaner in tank. it coughs and or hesitates when I'm coming from a stop to accelerating thru the intersection. Also, I was sitting in a drive thru waiting and noticed a rough idle so i put my truck in park and released the brake pedal and the idle returned to normal. I followed the instructions on the bottle
jrakers2
Mar 22, 2012 06:29 PM
ddog800
14
Feb 16, 2011 03:01 PM
88s10Blazer
May 10, 2010 08:52 AM
UnsoundRabbit
Sep 25, 2009 05:19 PM
ptcoins
Feb 19, 2008 10:46 AM
