RPO Specific
Old Jan 29, 2017 | 03:24 AM
cdtek101's Avatar
cdtek101 is on a distinguished road
Question RPO Specific
I have seen a report people post, but most are old outdated links
on this forum and others.
I have all my RPO codes from glove box and I have RPO code list,
but I just don't want to manually generate my own list, got to be
a easier way.
What I want is to be able to input my vin #
and have it show only my blazers RPO codes - Description
Like this;
A35 - Blah blah what ever
C12 - Blah blah what ever
D12 - Blah blah what ever
Anyone got a link that can do this ??
Old Jan 29, 2017 | 07:54 AM
Compnine.com was once free, but they charge $5 for 5 vin buildsheet decodes. Other than that, I am not aware of any other services that will do this short of begging your local dealer to give you a print out. In a quick search this morning, even the best of the free services that I found would only show you options, not actually list and detail each RPO code.
Old Jan 29, 2017 | 02:09 PM
Rusty Nuts's Avatar
I recommend biting the bullet and writing them down in a composition book. I fill the pages with the date, mileage, part, warranty and store of everything I do to my jimmy. It stays next to my envelope of receipts.
Old Jan 29, 2017 | 03:59 PM
cdtek101's Avatar
Well I went ahead and did the Compnine.com and bit the 5 dollar bullet.
Here is what I got;
Vehicle : BLAZER 4 DR
Year : 1999
Build Date : 02/25/1999
RPO Description
11U EXTERIOR COLOR,PEWTER MET (11U)
1SD PACKAGE-OPTION 04 (1SD)
6WH COMPONENT FRT LH COMPUTER SEL SUSP (6WH) SUSP(6WH)
7WH COMPONENT FRT RH COMPUTER SEL SUSP (7WH) SUSP(7WH)
91A STRIPE,COLOR ACCENT,TWO TONE,BEIGE/RED (91A)
92H TRIM COMBINATION CLOTH, MED DARK PEWTER (97) (H) (92H)
92I INTERIOR TRIM SHALE/PEWTER (92I)
A31 WINDOW,POWER OPERATED,ALL DOORS PWR WINDOWS(A31)
AG0 ADJUSTER SEAT, POWER, 8 WAY, 2 POSITION MEMORY, DRIVER 8 WAY POWER MEMORY ST ADJ(AG0)
AH8 ADJUSTER PASS ST POWER,8 WAY 8 WAY PWR ST ADJ(AH8)
AJ1 GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW) DEEP TINTED GLS(AJ1)
AN3 SEAT FRT, INDIVIDUAL/NON-BKT INDIVIDUAL FRT SEAT(AN3)
ANL PACKAGE,AIR DEFLECTOR AND FOG LAMPS A/DFL & FOG LP PKG(ANL)
AP9 NET,CONVENIENCE CONVENIENCE NET(AP9)
AU0 LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM) REMOTE ENTRY LK CONT(AU0)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
AXP VIN IDENT POSITION, MULTI- PURPOSE VEHICLE MULTI-PURPOSE VEHICLE VIN POSITION(AXP)
B30 CARPET,FLOOR AND WHEELHOUSE FLR CPT(B30)
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING BODY SI MLDG(B84)
C25 WIPER SYSTEM,REAR WINDOW RR WDO WPR(C25)
C3T GVW RATING 5350 LBS 5350 GVWR(C3T)
C68 AIR CONDITIONER,FRONT,AUTOMATIC,ELECTRONIC CONTROLS A/C AUTO ELEC CONT(C68)
D55 CONSOLE,FRONT COMPARTMENT FLOOR F/CMPT FLR CNSL(D55)
D96 STRIPE,BODY SIDE UPPER ACNT STRPE(D96)
DD0 MIRROR,O/S,R AND L REM CTL,ELEC,DEFOG,LT SENSITIVE O/S ELEC R/CON MIR(DD0)
DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LIGHT SENSITIVE I/S RR VIEW MIR,LIGHT SENSITIVE(DD8)
DH2 MIRROR,INSIDE, ILLUMINATED,LH & RH,WITH DUAL SUNSHADE ILLUM S/S MIR(DH2)
DK8 CONSOLE ROOF INTERIOR, DELUXE ROOF CONSOLE(DK8)
E55 GATE,END END GATE(E55)
EVA TEST DVT, EVAP EMISSION REQUIREMENT EVAP EMISSIONS REQUIRED(EVA)
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
FF6 ARM,TORSION BAR SPRING ADJUST,LH TORS BAR ADJ ARM(FF6)
FF7 ARM,TORSION BAR SPRING ADJUST,RH TORS BAR ADJ ARM(FF7)
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80)
GT4 AXLE,REAR,3.73 RATIO 3.73R(GT4)
JC1 BRAKE VAC POWER, 4 WHL DISC, 5,500 LBS BRAKE VAC PWR(JC1)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
K60 GENERATOR,100 AMPERE 100 AMP(K60)
L35 ENGINE,4.3L(4.3W),CPI,V6,90 DEG 4.3W(L35)
LIN PLANT CODE-LINDEN, NEW JERSEY (CPC) LINDEN, NJ PLANT CODE(LIN)
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
N33 STEERING COLUMN,TILT TYPE TILT STRG COL(N33)
N40 STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40)
N90 WHEEL,15X7(CAST ALUMINUM) AL WHL(N90)
NF2 EMISSION SYSTEM,FEDERAL,TIER 1 FED EMIS SYS(NF2)
NP5 STEERING WHEEL,LEATHER WRAPPED LEATHER WRAPPED STRG WHL(NP5)
NP8 TRANSFER CASE ACTIVE, TWO SPEED, PUSH BUTTON CONTROL TRANSFER CASE(NP8)
QBG TIRE ALL P235/70R15 WOL R/PE ST TL ALS 102S TIRE(QBG)
RSA RESTRAINT - FRT SEAT, 208, AUTO, PASSIVE
RYJ COVERING,CARGO AREA,RETRACTABLE RETRACTABLE CARGO CVR(RYJ)
SLM SALES PROCESSING - STOCK ORDERS
T61 LIGHTING,DAYTIME RUNNING DAYTIME RUNNING LGT(T61)
U16 TACHOMETER,ENGINE TACH(U16)
U73 ANTENNA,FIXED FIXED ANT(U73)
UA1 BATTERY,HEAVY DUTY HVY DUTY BAT(UA1)
UP0 RADIO AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC SEARCH CASS, CD, AUTO TONE, CLOCK, ETR. STEREO,AM/FM W/AUTO REV CASSETTE,CD,AUTO TONE(UP0)
UP8 RADIO,PROVISIONS FOR STEREO INSTRUMENTATION STEREO RDO PROVISIONS(UP8)
UY7 TRAILER WIRING,7 WIRE,2 LEAD FRONT HARNESS,5 LEAD REAR HARNESS 7 WIRE TRLR HARN(UY7)
V54 CARRIER,ROOF LUGGAGE(PAINTED) PAINTED RF LUGG CARR(V54)
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
VP6 NOISE LEVEL CONTROL NOISE LVL CONT(VP6)
VR4 TRAILER HITCH(WEIGHT DISTRIBUTING PLATFORM) EQLZR HITCH(VR4)
VXS VEHICLE - COMPLETE
X88 MARKET BRAND CHEVROLET CHEVROLET(X88)(EXPORT)
XBG TIRE FRONT P235/70R15 WOL R/PE ST TL ALS 102S TIRE(XBG)
YBG TIRE REAR P235/70R15 WOL R/PE ST TL ALS 102S TIRE(YBG)
YC6 DECOR PACKAGE/CL/SLE,#6(LUXURY) DECOR PKG #6/CL/SLE(YC6)
YD3 AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3)
YD5 SPRING,FRONT(BASE EQUIPMENT) FRT SPRING(YD5)
YD6 SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6)
Z82 TRAILERING PACKAGE(SPECIAL)(REESE TYPE HITCH) PROVISION FOR HD TRAILER EQUIP(Z82)
ZBG TIRE SPARE P235/70R15 WOL R/PE ST TL ALS 102S SPARE TIRE(ZBG)
ZM5 SHIELD PACKAGE,UNDERBODY U/B SHLD PKG(ZM5)
ZM8 PACKAGE,ELECTRIC TAILGATE RELEASE AND REAR DEFOGGER ELEC T/GATE REL & RR DEFG PKG(ZM8)
ZQ3 DRIVER CONVENIENCE PACKAGE II(MERCHANDISING OPTION) DRVR CONVENIENCE PKG(ZQ3)
ZQ6 DRIVER CONVENIENCE PACKAGE III DRVR CONVENIENCE PKG III(ZQ6)
ZW7 CHASSIS PACKAGE,PREMIUM SMOOTH RIDE PREMIUM SMOOTH RIDE CHAS PKG(ZW7)
ZY1 COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1)
Old Jan 31, 2017 | 12:09 PM
DARK1's Avatar
DARK1 is on a distinguished road
cdtek101
The inside of my glove box was spray painted by the PO. The only hope for the codes is through the VIN. I stopped when they wanted my Credit Card info. If you still have more VINs that you can run; I would be happy to barter with you. Or, at least, owe you a favor.
Old Jan 31, 2017 | 08:40 PM
cdtek101's Avatar
Originally Posted by DARK1
cdtek101
I think i have a extra free vin run left.... Send ur Vin to me
Old Jan 31, 2017 | 08:53 PM
DARK1's Avatar
OK. Sent as PM. Thank you.
Old Jan 31, 2017 | 09:17 PM
cdtek101's Avatar
Not sure if you got PM but I guess I used all free ones..sorry
...trustworthy site though
..www.compnine.com..
Helter80
Dec 22, 2013 11:44 AM
Chevy33
May 24, 2011 06:17 PM
farshot83
Performance & Brainstorming
Apr 23, 2011 12:03 PM
FireInMe17
Jan 2, 2011 04:31 PM
