Smoking and rough idle when I put on defroster
Old May 5, 2014 | 10:16 AM
Ryan02Stang's Avatar
Ryan02Stang is on a distinguished road
Default Smoking and rough idle when I put on defroster
I had no heat this past winter in my blazer, so I flushed our all the crappy dex-cool, flushed the heater core, and replaced the thermostat. I refilled with the green stuff that I've never had a problem with.
Everything runs perfect, and I have scorching hot heat now.
However, when I turn on my defroster, it starts idling rough and the engine starts smoking. I've found where the smoke is coming from...but I'm not even sure what it is. I've posted a picture.
Anyone have any idea what went wrong?
Attached Thumbnails Smoking and rough idle when I put on defroster-img_20140503_172226.jpg
Old May 5, 2014 | 11:16 AM
TrevT1's Avatar
TrevT1 is on a distinguished road
If you are talking about the thing the belt goes around, that is your A /C compressor, but I'm not sure why it would be smoking. Is it maybe seized up and the belt is slipping around it causing it to heat up? That would put strain on the engine.
Old May 5, 2014 | 12:06 PM
No...it is still spinning.
Old May 5, 2014 | 12:40 PM
richphotos's Avatar
the compressor must be on its way out, close to failing.
Old Jul 11, 2016 | 07:36 PM
mvamobile's Avatar
mvamobile is on a distinguished road
My compressor started smoking today and no cold air from A/C. Mine is still spinning also and it seems to be coming from the a/c clutch. Could the coolant be leaking from the front of the compressor and burning off causing the smoking?
blazerguy22
Nov 14, 2013 11:50 PM
blazer chris
Dec 8, 2011 09:56 AM
UnknownFish
22
Nov 14, 2011 07:40 AM
1blazer99
Sep 27, 2009 10:55 AM
c10jm
Aug 12, 2008 05:34 PM
