So here I was driving down the road...
#21
Is it bad when you can see your crank shaft? ![Big Grin](https://blazerforum.com/forum/images/smilies/biggrin.gif)
[IMG]local://upfiles/5070/A2CE27A069E74CD399C946D0669C71A7.jpg[/IMG]
[IMG]local://upfiles/5070/0DA350362C5349A3881C53761E7FDB47.jpg[/IMG]
[IMG]local://upfiles/5070/2600B9A9AB284E099F8EEF3F4F0B652E.jpg[/IMG]
[IMG]local://upfiles/5070/7DC335A02EFF475B914E251DC8BDC8CB.jpg[/IMG]
#22
THERE SHOW BLOWS
*Combining Consecutive Posts*
Look at the boof mark on the crank AND I DONT CARE ABOUT MY DOUBLE POST.
*EDIT by swartlkk* - Use the EDIT feature.
ORIGINAL: drperry
#23
ORIGINAL: drperry
Is it bad when you can see your crank shaft?![Big Grin](https://blazerforum.com/forum/images/smilies/biggrin.gif)
#24
That's just a love tap...
#25
That's purdy! Must have lost a rod. Are you sure it didn't make any noises before it died on ya?? How loud did you have the music cranked?
#26
At about 20 out of 35.... You can still hear cars and trucks passing you
So yeah, shopping time, lol.
#27
Wow..so..what part exactly is missing? For the non-engine-part literate..that's the lower engine, blew off the oil pan and a bit more? The crankshaft sits at the bottom of the V right?
Pardon my ignorance![](https://blazerforum.com/image/s1.gif)
Pardon my ignorance
#28
The oil pan is actually a structural part of the engine on the newer engines, don't know when it started. Meaning there's no separate oil pan that you can drop with a gasket in between. Looks like the actual casing cracked and fell off.
#29
Ah ok..yea I can definitely see the cracked/broken edges on the left and right of the pic.
#30
The oil pan is still replaceable even though it is a 'structural' part of the engine. The change happened between '97 & '98 when they moved from the stamped steel pan to the cast aluminum pan. The aluminum pan is sealed with an o-ring as opposed to the old gasket that could be over compressed.
From the looks of it, something came loose in the rotating assembly (#1 or #2 cylinder rod would be my guess) and smashed the pan good. No other reason for that to happen really...
