Starting issues
Old Dec 10, 2013 | 06:31 PM
srr295's Avatar
srr295 is on a distinguished road
Default Starting issues
I have a 2001 Chevy Blazer. Car ran a little rough before this but, we recently hard two days of a hard freeze after which my blazer would not crank. Battery sounded dead turns out needed to be replaced. I will add before I removed it to be replaced the engine did start one last time. I replaced the battery now it will turn over but never start, sounds like it fires every now and then. I did put gas in the carburetor to see if I could kickstart it. I thought maybe it was flooded and tried any techniques to find out even check and filter and pump are fine too.....ANY HELP?
Old Apr 12, 2014 | 07:46 AM
Robert Lee Hicks's Avatar
Robert Lee Hicks is on a distinguished road
I had the same problem with my 2001 blazer , I replaced thunder the coil pick-up under the rotor cap , I noticed there was moisture on the cap so I replaced the dist. cap and rotor .... no more starting problems ... Good luck ...
cgrett
Nov 15, 2010 09:08 PM
tadder52
Dec 18, 2009 09:38 PM
Sprocket
Mar 20, 2008 09:39 PM
dragonsdeath
Oct 7, 2006 01:08 AM
BuddaBoy
Engine & Internal
Dec 7, 2005 03:36 PM
