steering shaft knocking on my '03, what is it?
Old Mar 29, 2012 | 05:14 PM
egbert567's Avatar
egbert567 is on a distinguished road
Default steering shaft knocking on my '03, what is it?
I have a knocking noise in my steering shaft area when I go over bumps.
Old Mar 30, 2012 | 07:56 PM
Rottidog's Avatar
Could be the pitman arm, rag joint or anything else that's attached to the steering assembly like a ball joint or idler arm, upper or lower bushings. Have you lifted the front of the vehicle & tried to move the tires? Grab the top & bottom of each tire & try to rock it front & back & then left to right.
Old Mar 30, 2012 | 08:50 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
The torsion bar mounts could be bad .
Old Mar 31, 2012 | 09:02 AM
egbert567's Avatar
Default Steering "Knock" in '03 Blazer
It's an internal, inside the cab noise...Anyone know if the S series Blazers were plagued with the same intermediate steering shaft issue that the Silverado/Sierras were?
Old Mar 31, 2012 | 09:04 AM
egbert567's Avatar
Checking on everyone's suggestions as well, thanks! It's my daily driver with 67K on it. I'm thinking it can't be an external steering component...yet...
Old Mar 31, 2012 | 10:23 AM
50lb_cat's Avatar
Could be a lot of things, like the previous post said best thing to do would be to shake down the entire suspension.
Old Apr 1, 2012 | 10:57 AM
Rottidog's Avatar
Try getting under the dash & twisting the steering shaft back n forth & trying to move it up & down, side to side etc. Then do the same under the hood looking for play. With the hood up get a heavy friend to try bouncing on the bumper to cycle the suspension a bit while you watch the steering shaft to see if it interferes with anything.
Tony H
Sep 7, 2010 07:45 AM
polecat
Sep 25, 2008 11:46 AM
1990blackgt
Oct 21, 2007 05:56 AM
lennyblazer
Jul 11, 2007 02:24 PM
Bigjoey71
Suspension Tech
Jan 3, 2006 12:28 AM
