A/T tires on rear only?
Old Jan 13, 2019 | 11:21 AM
puttster's Avatar
Default A/T tires on rear only?
After some rear end slip sliding, I am looking for better grip on wet roads. Since I have a 2wd (Xtreme) I probably can stick with all-season on the front and switch to some all-terrain tires on the back, like BFG Rugged Terrain or maybe Dynapro AT-M, Wranglers, etc.
Am I right to assume that A/T will be better than A/S in rain? Am I also correct that putting A/T tires on the front will not significantly improve traction?
Finally, if they don't match will people wonder "why can't this guy afford matching tires," If they do match, they might wonder, "why is he pretending to have a 4wd off-road truck?"
Old Jan 13, 2019 | 11:57 AM
cleburne red's Avatar
I'm no expert, but I would think you would want matching tires all around. Imo, the front needs just as much grip as the rear, since it does most of the braking, as well as steering you.
Old Jan 13, 2019 | 06:57 PM
I try and find as close to the season tire as I can. I've notice that the "all season" tires have never given me the full grip like "season" tires do. Now that I have been doing more, take off the path roads, going for more mud/road for summer, and mud/snow for winter...
edit: forgot to mention that I always make sure the 4 are the same, if possible the spare as well...
Old Jan 14, 2019 | 08:33 AM
rriddle3's Avatar
A/T tires will provide less traction on a wet road than all-season will due to less contact points from the tread blocks.
Old Jan 14, 2019 | 04:04 PM
puttster's Avatar
Good info, I will skip the all-season and match all four. Am reading reviews to see which broad gives a good wet ride.
Old Jan 14, 2019 | 07:19 PM
go chevy's Avatar
I would agree with everybody else, it is probably a better idea too have 4 matching tires, especially when it comes time too rotate them...
Old Jan 16, 2019 | 10:43 AM
puttster's Avatar
I got a deal on Walmart Rugged Terrains. They look great and have circumferential grooves for shedding water. They are bigger than stock, 235/70 vs 235/60. When I cut the wheels sharp, as in backing out of the driveway into the street, they grind on the back of the wheel well. Who knew an extra .8" diameter would matter?
This might not be the right forum to ask but for those who have been following, what's the solution?
Old Jan 16, 2019 | 11:40 AM
Those tires shouldn't rub at all. Mine used to have 235/75-15 on it, and didn't rub anywhere.
Before I rebuilt the front end, and got an alignment, one side would rub on the sway bar at full lock, but the alignment fixed that
Old Jan 16, 2019 | 01:28 PM
puttster's Avatar
The Xtremes have a 2" drop vs the regular Blazer, which is probably causing the problem. I am guessing that the Xtreme's stock 235/60R16 profile tires were to avoid the contact and when I put 235/70R60's on... well, anyway, I'm still looking for some fixit ideas.
later edit: After removing the tire I saw a place in the frame where I could insert a crowbar. I Inserted a piece of wood between the bar and the point of contact and levered that to push the metal back. Then a touch up with the BFH and I am okay. P.S., On an Xtreme, the point of contact is a good 9" into the wheel well and pretty high. It is still pretty close, No way would a 235/75R16 have fit under there without some cutting.
Old Jan 16, 2019 | 01:40 PM
Oh, my bad. Forgot y'all were talking about the xtremes. Carry on!
02_Blazer4x4CWP
Mar 27, 2013 10:40 AM
jman_08
Tires and Wheels
Jan 1, 2011 09:43 PM
Chevyguy032
Tires and Wheels
Oct 27, 2008 10:02 PM
94blueknight
Tires and Wheels
Feb 15, 2008 09:44 AM
EuroGoldLS
Tires and Wheels
Mar 31, 2007 08:36 AM
