tailgate window problem
not sure where you're from, but i had corrosion problems with the wires where they went from the body to the TG on my 1st 'Burb. also noticed that the wires @ the firewall were worn through a little on a pinch weld, and could've possibly been shorting there as well.
i found both of those as i was tracing my own no movement issues. fixed them both @ the same time, never had any issues after that.
yes the window goes down when using the inside switch,however,if the tailgate was not latched just rite the window would.not go up I removed the acess panel and bypassed that problem. but the key switch still will not work. I live in california so I dont think corrosion itself is the problem. im stumped.
kwerts
Nov 4, 2009 07:13 AM
