good performance uprgrades?
Old Apr 13, 2011 | 03:10 PM
charlie merrittiv's Avatar
charlie merrittiv is on a distinguished road
Default good performance uprgrades?
im looking for any good ideas for a 1994 chevy s10 blazer. ive got the 4.3l. any ideas for good upgrades?
Old Apr 13, 2011 | 03:49 PM
G_Doughty's Avatar
G_Doughty is on a distinguished road
How much money do you want to spend? Volkswagen GTI AFE Cold Air Intake Performance Upgrade Portland
Old Apr 16, 2011 | 09:53 PM
i consider it a work in progress so probably around 500 bucks
Old Apr 16, 2011 | 10:19 PM
matt92's Avatar
matt92 is on a distinguished road
cold air intake, flow master exhaust, low temp thermostat, msd ignition, good spark plug wires.
Old Apr 17, 2011 | 08:15 PM
4x4blazerguy's Avatar
What does a low temp thermo do for performance since these newer vehicles need heat to burn the gas & run right?
Old Apr 18, 2011 | 04:41 AM
ohsofly's Avatar
The lower temp thermo keeps the running temp below normal resulting in a richer mixture and denser air charge. Most engines .run rich until operating temp. Its really not the best of ideas and will waste some gas unneccessarily
You may also want to run an underdrive crank pulley to free up some power too. Adjust the fuel pressure to 63 from 58 where it probably is. Also check your spider injector for wear too cause its going to go on you.
The CAI, exhaust pipes and coil are all good ideas for you. These V6 sound cool when the exhaust is opened up. You will se how twisty and turny the air intake tube is on your engine on its way to your fender. Switch that up for one of those kits with a wall thing that relocates the filter to somewhere cool and long straight tubing. Thats going to give you the most pop for your dollar.
Rselarep
Dec 11, 2011 07:14 AM
theclothedcreature
Tires and Wheels
24
May 20, 2010 07:07 PM
blazerboy1998
Performance & Brainstorming
Aug 31, 2009 02:23 AM
99s10blazer
Jun 1, 2007 09:13 AM
lukewb
14
Dec 2, 2006 02:23 AM
