tailgate window problem
Old Feb 14, 2011 | 01:32 PM
88blazerK5's Avatar
88blazerK5 is on a distinguished road
Default tailgate window problem
tthe tailgate window won't go up or down when I use the key in the tailgate . I cant find a replacement switch.Any suggestions?
Old Feb 15, 2011 | 09:38 AM
JTalley's Avatar
JTalley is on a distinguished road
It might be a short or possibly a disconnected wire. Does the window go down when you use the switch inside?
Old Feb 15, 2011 | 08:09 PM
abig84's Avatar
gonna have to climb back there and take off that access panel. see if power is going to the motor and you may have to jump the motor to get it down just to get the gate open to work on it easier
Old Feb 15, 2011 | 10:38 PM
old skool luvr's Avatar
not sure where you're from, but i had corrosion problems with the wires where they went from the body to the TG on my 1st 'Burb. also noticed that the wires @ the firewall were worn through a little on a pinch weld, and could've possibly been shorting there as well.
i found both of those as i was tracing my own no movement issues. fixed them both @ the same time, never had any issues after that.
Old Apr 18, 2011 | 02:38 AM
88blazerK5's Avatar
yes the window goes down when using the inside switch,however,if the tailgate was not latched just rite the window would.not go up I removed the acess panel and bypassed that problem. but the key switch still will not work. I live in california so I dont think corrosion itself is the problem. im stumped.
RobRad
Mar 24, 2014 06:08 PM
Brickroad
Apr 18, 2010 10:32 AM
kwerts
Nov 4, 2009 07:13 AM
mwjungaz
Aug 24, 2006 09:10 PM
sleonh
Mar 29, 2005 03:32 PM
