taking off in 3rd
Old Aug 21, 2007 | 07:27 AM
WhiteTie BlackJacket's Avatar
WhiteTie BlackJacket is an unknown quantity at this point
Default taking off in 3rd
will taking off in 3rd help save any gas?
Old Aug 21, 2007 | 07:32 AM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
Default RE: taking off in 3rd
I doubt it. When you take off in third, you still go through 1st and 2nd. Overdrive is designed to keep the RPMs down, thus saving gas.
Old Aug 21, 2007 | 08:16 AM
rriddle3's Avatar
I 'm guessing you have a standard tranny? No, taking off in 3rd won't help much since you would have to rev the engine up to get the rpm's high enough to get going. If you try to keep the rpm's down by going easy on the gas, you will wind up lugging the engine which is not good for it over time. The way the Blazer is geared (unless you have a really low ratio rear axle) it's best to work through the gears when starting off.
ah ok. thanks euro. no rriddle i have an automatic. guess i shoudlve said thatinitially
Old Aug 21, 2007 | 08:34 AM
Yeah, 3rd in an Auto tranny just locks out OD... Doesn't change anything as far as the shift points go.
Old Aug 21, 2007 | 12:04 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
we couldve guessed that u had an auto in the blazer seeing as how they did not make a 4 dr 2nd gen manual.... you could only get the manual in the 2 door model for the 2nd gen s-10 blazers
Old Aug 21, 2007 | 02:37 PM
lol maybe you couldve, but not me. i didnt know that, thats neat.
Old Aug 21, 2007 | 02:43 PM
BLK85's Avatar
BLK85 is an unknown quantity at this point
ORIGINAL: a_tack
Learn something new everyday.
Old Aug 21, 2007 | 02:49 PM
rriddle3's Avatar
Of course the easiest way to avoid these little glitches is to incorporate the important info about your truck into your signature line like I did below.
Old Aug 23, 2007 | 08:11 PM
drperry's Avatar
The Blazer is more than torquey enough in the low RPM to start in 2nd (for all the 5 speed people)
1st is geared fairly steep... Starting in 3rd is not reccomended, though... the ratio for 3rd is entirely to tall for that...
Maybe with the 3.73's or 4.10s you can do it, but not on a 3.42 or lower
piggyb00
25
Feb 16, 2008 10:33 PM
vermillion2
Jun 18, 2007 07:17 AM
S10Blazer
Oct 9, 2006 11:45 PM
88s10Blazer
Sep 2, 2006 01:22 PM
blazer3
Engine & Internal
Jun 23, 2006 01:26 AM
