Torque specifacations
Old Sep 29, 2015 | 08:13 PM
johnnylovsey's Avatar
johnnylovsey is on a distinguished road
Default Torque specifacations
I Have a 2003 Blazer L/S 4.3 liter any one out there help me with the torque spec,s on the upper intake manifold bolts and the valve cover bolts.
Old Oct 1, 2015 | 11:36 AM
rThe values you are requesting have been requested and provided in past threads. A quick search for either "intake+manifold+torque" or "valve+cover+toque" (without the quotes) will turn up the relevant threads/information.
Old Apr 22, 2021 | 05:13 PM
nomoresubies's Avatar
nomoresubies is on a distinguished road
Tried that. Getting nowhere....
Old Apr 23, 2021 | 09:06 AM
Vahomboy's Avatar
Vahomboy is on a distinguished road
See this thread, post 14.
Lower intake gasket replacement - Blazer Forum - Chevy Blazer Forums,
Install the manifold and bolts and tighten the bolts in this sequence:
Tighten the bolts in sequence to 26 inch pounds (some versions of the factory manuals say 27 inch pounds, but I doubt 1 inch pound difference matters).
Then tighten the bolts in sequence to 106 inch pounds.
Then tighten the bolts in sequence to 132 inch pounds (11 foot pounds).
This is a job for the 1/4 drive "inch pound" torque wrench.
Old Apr 23, 2021 | 10:36 AM
Thanks for all that information but the search for torquing the intake manifold was just an example in the previous post. I was looking for u-joint and pinion nut specs. I posted here because I did a fair amount of searching in the forums with various keywords and just couldn't come up with anything. I got some specs from the net and wound up snapping a u-joint bolt so had to remove the pinion flange to remove it. Now I need to torque that back on...
Old Apr 24, 2021 | 07:57 AM
Considering this thread is over 5 years old and has been answered to the extent necessary on the topic it was originally created for, it will be closed.
yako
Feb 13, 2017 10:29 PM
OdysseyMsc
Mar 30, 2014 06:00 PM
ant2297
Oct 13, 2009 01:17 PM
98SmokeBlazer
Nov 15, 2007 10:32 PM
