Truck dies and wont start
Old Aug 30, 2017 | 10:22 PM
Trevor92's Avatar
Trevor92 is on a distinguished road
Default Truck dies and wont start
I have no idead what is causing this and need a little help. My 92 s10 blazer has the 4.3 tbi and it recently died and wouldnt start back up so i hauled it home and let it sit for the weekend and when i turned the key it started right up. So i took it around the block and it died half way around the block and once again wouldnt start. After i got it home i disconnected the fuel line off the throttle body and cranked the motor to see if the fuel pump was pumpin fuel and it squirted out gas like it should. So i tested the fuel injector connectors with a noid lite and they worked just fine, after that i bought 2 new fuel injectors and put them in. I got everything hooked back up and jumped it off and it ran great so i took it around the block and after the 2nd or 3rd lap it died again and wont start. It gets fire and turns over but wont start.
Old Aug 31, 2017 | 07:48 AM
don james's Avatar
don james is on a distinguished road
I would start with a new fuel filter......that's the easiest .....sounds like a No fuel deal.....
Old Sep 1, 2017 | 02:16 AM
ignition module on the distributor
They sometimes die as soon as they warm up.
Might even be that it starts cold, runs great and cannot be restarted after shutdown when warm.
15$ - 25$ fix
Old Sep 1, 2017 | 06:10 PM
Trevor92's Avatar
Tried the fuel filter...didnt solve the problem but thanks for the suggestion
Old Sep 1, 2017 | 07:23 PM
don james's Avatar
I know that the filter can get fuel thru it to run for a while then plug and kill ya...then after the pressure goes down the dirt backflushes then you can start and run again.... that's why i suggested it first.......
I heard a story once about a fuel sock on the fuel pump that would randomly fold and cut fuel supply........but that may be a long shot.....??
I've finally learned to start with easiest and go on to the next, after 68 years :-)
I'll keep posted on what you do.....
JimmyBlaze541
May 2, 2013 10:00 AM
daveiam
Jan 31, 2011 10:22 AM
jt32404
Jul 30, 2010 10:55 AM
Poligono
Nov 3, 2008 06:01 PM
DerCribben
Nov 15, 2007 06:41 PM
