upper display 1998
Old Apr 30, 2022 | 05:10 PM
hdwingding's Avatar
hdwingding is on a distinguished road
Default upper display 1998
The upper display. Where you read outside air temp/ mileage, Etc. Is there a fuse for this? mine is out.
Old Apr 30, 2022 | 07:05 PM
This should be in your owners manual. If you don't have one, you should be able to download one.
Old May 1, 2022 | 10:02 AM
TDS-MN's Avatar
TDS-MN is on a distinguished road
Isn't there a way to toggle that display setting between on and off? I sold off the Blazer a while back, but going from memory, thought I had turned that display off once. . . . Could it be that simple? Seem smore likely than a fuse., IMO.
Old May 1, 2022 | 12:49 PM
You can turn it off by sequentially pressing the mode button that also cycles the display through all of its readings.
Old May 15, 2022 | 12:29 PM
hdwingding's Avatar
I understand the functions of the buttons. The display is dark. no matter what i do or push.
Old May 15, 2022 | 12:41 PM
Mods's Avatar
Due to the proximity to the roof and the lack of insulation above it, those modules are starting to have a reputation for going out on the older rigs among us due to heat stress induced failure. Try adjusting your cab dimmer switch and see if you can see anything at all, and failing that i will try to find a wiring diagram for it so i can point you in the right direction for diagnostics.
Old May 15, 2022 | 02:18 PM
hdwingding's Avatar
thank you
Old May 18, 2022 | 07:38 PM
roddy's Avatar
roddy will become famous soon enough
Smile
Fuse block and DIC wiring diagrams
RDO IGN (fuse 24) supplies 12 volt supply for DIC
File Type: pdf
File Type: pdf
BIG A
Mar 31, 2017 06:23 AM
ayla
Mar 3, 2014 08:17 PM
mritech
Nov 26, 2010 07:53 AM
fuganator
Jun 2, 2009 09:35 PM
DaddyCop03
May 11, 2008 09:07 PM
