Using Overdrive in City Driving?
Old Jun 5, 2013 | 11:11 AM
  #21
chris015's Avatar
Originally Posted by phxjosh
Anyone know why my RPM's were higher in Drive? Could it be a transmission issue?
I tried it again today, same result, at any speed over 40 MPH I had much higher RPM's.
its normal. in overdrive you have that extra gear that helps lower rpm. drop that gear and you gain some rpms. Completely normal. drive is mainly for towing,or like other people said already. They like that the rpms are a little higher and in a better part of the power curve. aka a lil preppier in throttle response.
Old Jun 6, 2013 | 02:12 AM
  #22
Rumblur's Avatar
Rumblur is on a distinguished road
a habit I picked up driving Mopars, once the engine is running drop the trans in Neutral. Let it warm up 10-30 seconds before dropping in R or OD.
On a mopar, the pump doesn't pressurize the system until you leave Park. So the trans is cold even if the engine is at operating temp. I know GM's work differently, but I do it anyway
Old Jun 6, 2013 | 02:19 AM
  #23
Rumblur's Avatar
Old Jun 6, 2013 | 07:33 AM
  #24
Neb15's Avatar
Neb15 is on a distinguished road
My seccond gear seems to stay in two and not drop to first, even from a dead start. Third will shift down and I thik it's my drive and the d is my od.
Old Jun 6, 2013 | 10:43 AM
  #25
El_Beautor's Avatar
That's correct. 2 will hold the transmission in 2nd gear, and the same goes for 1st. 3 is the same as D in the older Blazers like mine.
Old Jun 7, 2013 | 07:07 AM
  #26
RE849's Avatar
RE849 is on a distinguished road
not sure about this but heard that driving in od in the city will wear out the yoke and you'll soon be getting a clunking when the gears change.
Old Jun 7, 2013 | 09:22 AM
  #27
grizzstang's Avatar
grizzstang is on a distinguished road
I can't see how. Your yoke sees the same wear either way. It does not know what gear you are in.
I have always shut off the electronic over drive when tooling around town. More than one trans expert has told me that overdrive is the weakest link in most transmissions. I have found that it just switches in and out of od when I use it around town anyway. I do this in my F150 and my Tercel but our Blazer does not have an electronic overdrive so I just put it in drive and go. So the older Blazers have an od button?
Old Jun 7, 2013 | 10:03 AM
  #28
BigBlackBlazer's Avatar
BigBlackBlazer is on a distinguished road
Hope Im not hijacking, but my 02 blazer has a 4 speed automatic transmission, and on the dash it has 1 2 3 D. I believe selecting 1-3 will lock out all other gears- so is D the only way to get to OD on my tranny? Is 4th gear the same as OD?
Old Jun 7, 2013 | 05:20 PM
  #29
cleburne red's Avatar
Yes. 4th is OD. 3rd is a 1:1 ratio, and 4th is the overdrive gear. While you could technically call it a 4 speed, it's more of a three speed automatic with overdrive.
Although nobody calls a 5-speed stick shift a 4 speed with overdrive. So, it's really just semantics, I guess.
Old Jun 7, 2013 | 07:19 PM
  #30
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
none of the blazers have an overdrive button but by putting it in the highest gear selection you are putting it in overdrive.
