Vibration in Front end.
Old Oct 26, 2009 | 05:00 PM
wGraves's Avatar
wGraves is an unknown quantity at this point
Default Vibration in Front end.
Ok Well I've been having a vibration in my front end for a few months now and I decided last week to try to find out what is was. So First off I changed all 4 tires because of uneven wear. Helped a bit but still was there. Then changed both upper ball joints. That helped too but now I'm stumped. Now it vibrates only when I turn the wheel to the left or hit a hump in the road. Anyone have any clue what this could be?
Old Oct 27, 2009 | 10:33 AM
Unlimitedsp's Avatar
Sounds like you have a bad wheel bearing. Its a common problem with these trucks.
Old Oct 27, 2009 | 03:59 PM
old skool luvr's Avatar
when you did the BJ's, did you inspect the idler arm & pitman arm? you don't mention what year your truck is, or the mileage on it, but i had to do the pitman arm on my '98 when i bought it last Christmas, and the truck only had 158K on it (98,000 miles).
i changed the idler arm while i was @ it, 'cause if the pitman is shot, it's gonna put a strain on the idler as well.
Old Oct 28, 2009 | 06:50 PM
wGraves's Avatar
It's a 1996, Body,Trans and anything but the motor have around 240,000 miles on them and the motor is about 150,000
ZR2Driver
Jan 21, 2010 03:08 PM
vrryder
Oct 30, 2009 10:56 PM
Kendo
13
May 22, 2009 11:44 AM
SanfordBlazer
Feb 27, 2009 07:49 PM
miso
13
Jan 2, 2007 10:20 AM
