Ways to Lift?
Old Apr 14, 2008 | 11:20 PM
zac11zebra's Avatar
zac11zebra is an unknown quantity at this point
Default Ways to Lift?
Im lookin for a cheap way to liftmy 01 blazer 2 dr at least 3-6 in?
wat r some methods/products
Old Apr 14, 2008 | 11:28 PM
spartan's Avatar
spartan is an unknown quantity at this point
Default RE: Ways to Lift?
Floor jacks work well.
WolfPack's Avatar
Buy some huge truck tires...maybe 37s. That'll be 4' of lift from the tires alone!
Sorry didn't see you said cheap. Floor jacks would be cheapest...but I have saftey concerns...use the jack stands for long term use.
Old Apr 15, 2008 | 02:35 AM
Taymacjack's Avatar
The cheapest lift you could do is a torsion bar crank and shackles for your lief springs. That will give you 2 inches and will costabout 30bucks. then do a 2" body lift. That will cost you about 120 with shipping from Jcwhitney. so all together you will get 4 inches of lift and it will cost about $150 bucks.
Old Apr 15, 2008 | 06:53 AM
WolfPack's Avatar
2' BL for a 98-04 runs $220 (and jc whitney does not stock a 2' kit for 98+ blazers from what I could find). And as with any mention of the shackle and t-bar lift, you'll need to consider front end wear. That's a hidden cost to the lift you're going to want to plan for....balljoints and CVs are not cheap if you have to pay to get it done.
Which brings us back to jack stands. Or big tires.
Old Apr 15, 2008 | 01:35 PM
Taymacjack's Avatar
ORIGINAL: WolfPack
Dang...I guess they don't make a semi cheap body lift for 2001. And its true that you may experience accelerated wear if you do a t bar crank. I think i only went 1.5 when i did mine. If the ball joints have fittings (I'm not sure if the stock ball joints even have them) you would really want to make sure you keep them greased. Bottom line is that a tbar crank and shackles is the cheapest way to lift , but may cause more front end wear.
Blazerboy1611
13
Feb 14, 2010 06:58 PM
N3ROST4R
Lifting Tech
Dec 22, 2009 12:19 AM
PaulO2288
Aug 24, 2009 05:18 AM
1982blazed
Jun 23, 2009 07:39 PM
spankyy
Performance & Brainstorming
Feb 28, 2009 11:01 AM
