What causes this to happen?
Old Sep 1, 2012 | 08:25 AM
Little Roober's Avatar
Little Roober is on a distinguished road
Default What causes this to happen?
First off, I know that brake squeak is much more common with ceramic pads because they're harder than the standard metallic pads...
But what actually causes the squeaking? Heat, moisture,brake dust???
I put brand new rotors, pads and a caliper in and within a few hundred miles of driving they squeak 80% of the time while slowing down.
I asked one of the mechanics at work and he didn't really know either.
Thanks fellas,
Steve
Old Sep 1, 2012 | 10:39 AM
Presti7's Avatar
Presti7 is an unknown quantity at this point
Cheapo brake pads...I got some once from IC Whitney and they were horrific....too abrasive/hard of a brake material.
Before you replace them get some of that anti-squeal grease and put a little on the BACK side of the pads.
From experience.....some of the brake pads they sell are just bad. Be careful where you buy them from.
Old Sep 1, 2012 | 11:24 AM
okiedoak20's Avatar
i personally never had good expeiences with ceramic pads, too many issues, semi metallic for me is the way to go, heck after all this truck
aint no sports car,and no matter what pads i install it wont stop on a dime,or give any change Hehe
Old Sep 1, 2012 | 12:36 PM
The main cause, (not the only cause) of brake squeal is "pad slapping" ** and re-using the original, glazed rotors. When the pads are replaced, they need a good non-directional finish on the rotors to bed properly. Without the finish, they'll squeal for as long as they're on the vehicle. If the non-directional finish is good, you can use el cheapo pads or ceramic pads, without using "snake oil" on them, and they won't squeal. Original brakes don't use any of that stuff, so if you do the job right, you won't need it either. If the brakes are squealing, somebody did a halfass job.
** Pad slap is replacing just the pads and calling it a brake job. That's not even halfass, more like quarterass
Old Sep 2, 2012 | 11:24 AM
Well, like I said, i replaced a caliper both rotors and the pads, and also lubed everything up. What else would I do?
Old Sep 2, 2012 | 01:26 PM
Did the new rotors have a finish like this when you installed them?
You can feel the "grooves" when you run your hand over them, (it is not smooth). This type of finish is necessary for the pads to bed, (seat) correctly. Without this finish, you can expect the pads to squeal when applying the brakes. The finish will wear off as you use the brakes and the pads bed properly. Depending on how hard you are on your brakes, it can take ~1000 miles to wear off.
Old Sep 2, 2012 | 03:57 PM
cleburne red's Avatar
I've had the opposite experiences with ceramic pads. I used semi-metallic years ago, and they always squeeled and produced a ton of brake dust. They didn't last very long, either. I switched to ceramic, and haven't had a problem, since. I don't use the high performance, expensive ones. Just either the cheap, or maybe mid-grade ceramic pads. Also, the new pads need to be bedded in properly. There are different schools of thought on this, but usually the manufacturer has a break-in procedure for their pads.
Old Sep 3, 2012 | 08:47 PM
Well, apparently I hit the break in period. They've only squealed once or twice in the last 2 days. Thanks fellas.
Blazn1
Lifting Tech
Oct 15, 2009 02:40 PM
blznlowxtreme
Aug 26, 2007 11:46 AM
Hanr3
Apr 8, 2007 10:08 PM
skitzobmxr
Dec 17, 2006 09:57 PM
ivannj
Jan 9, 2006 01:40 AM
