What PSI Should I Put in my Tires?
if you have a long commute, you dont want to run you tires at the max psi. like Grizzstang said, you will burn the middle of the tires out. you also have to think about expansion. if you have 50 psi in your tires and then you drive about 50-70 miles, you could have as much as 55 psi at the end of the run. if its hot outside, the problem gets worse. thats why i run mine low even when i am loaded down for a long trip. i went to Parker, AZ from Long Beach, CA and i managed about 20-21 MPG.
the best thing that you can do is pay attention to tire wear and check the pressure often.
37 rear/ 35 front running light-40/40 at GVWR
Goodyear SR-A 235-15(whites in!) 40k only half worn!
Mine is a highway Jimmy,but has proved itself!
Never been stuck,but if the going gets tough,
the go pedal gets used! This is not an off road vehicle,
but it has never let me down with prudent caution either....
93LT
Jan 16, 2006 09:36 PM
