What rearends are in the Blazers?
Old Jan 16, 2007 | 10:16 AM
drperry's Avatar
Default RE: What rearends are in the Blazers?
ORIGINAL: swartlkk
It all depends on if you have the G80 locker or not. In an open case, everything can be installed without removing the carrier. If you have the G80, I don't think anything goes into a G80 carrier... So that means you'd need to find an open diff carrier and transfer over your gears, install new bearings, then install the posi/locker unit of your choice.
Bollocks! lol
I've got the G80 -_-
Old Feb 14, 2007 | 01:20 AM
Mapoftazifosho's Avatar
Mapoftazifosho is an unknown quantity at this point
I am showing codes gt4, g67, and g80.
So I have 3.73, positraction, and the level control.
What is the level control?! The autoride?!
I thought that was ZW7, which I am showing in my glove box.
One last thing, the positraction diffs how do they work?! Gears or clutches? I will search for a diagram in the meantime.
Also what kind of synthetic diff fluid do you all run?! I will do my research on this, but I am just curious.
Old Feb 14, 2007 | 07:02 PM
ma96782's Avatar
ma96782 is an unknown quantity at this point
Rear End ID:
http://www.drivetrainspecialists.com/categories/gm/
RPO Codes:
http://www.fullsizechevy.com/forums/...ight=rpo+codes
Don't know if it still works for RPO Codes:
http://www.c2e.info/rpocodes/MODERNGMRPO.html
Aloha, Mark
Old Jun 7, 2007 | 12:13 PM
Hanr3's Avatar
Ths codes listed by Chevy Lover look to be for a Fullsize Blazer and not the S-Series Blazer.
I'll see if I can find the S-series version.
Edited. Try this version. Enter your codes and click check codes.
http://www.s10forum.com/rpo/index.php
Old Jun 7, 2007 | 12:45 PM
Jigg's Avatar
Jigg is an unknown quantity at this point
Some non-ZR2's came with the 8.5" rear end actually. Here's the one on the '98 blazer i bought to part out:
and here's one from a '97 ZR2:
and here's one from a '97 non-z blazer:
and here's the newerone on my '00 blazer ZR2:
The 8.5's have square tabs on the bottom of the diff, compared to the pointier tabs on the smaller rears, like in my brother's blazer:
Old Jun 7, 2007 | 04:27 PM
drperry's Avatar
Must've been a hidden factory option or something... Wonder how hard it'd be to swap out the axle/rear end... lol
Old Jun 7, 2007 | 08:49 PM
Jigg's Avatar
Not that hard really... i've got one for sale if you want it
It even has a G80, disc brakes,and 3.42 gears... you'd be all set! Between the 8.5" rear and the iron front diff you have, you'd be pretty well setup for lockers!
Old Jun 7, 2007 | 11:03 PM
Hanr3's Avatar
Thanks for the info on the 8.5" in non-ZR2 trucks. Are there any other ways to identify them? Like id dthey only come behind manual tranny trucks, or something like that? Is there a code in the glove box for them?
Old Jun 7, 2007 | 11:14 PM
Jigg's Avatar
There's no code in the glovebox, but i do know that the squared off tabs are a dead indication.
Also, all 5spd blazers and S10's from 95 on (i believe, it might ahve been earlier) came with an iron front diff... so i wouldn't put it past GM to have included the 8.5" rear end in that unspoken package.
Old Jun 7, 2007 | 11:26 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
You may be onto something with the manual trans only thing Tim, a buddy had a 2003 s-10 with ZQ8 suspension, he ordered it with a manual trans and a 3.08 gear because it was the steepest gear ratio you could get that year with a manual trans. So the day after he took delivery of it we ordered a 3.73:1 gearset for a 7 5/8" rear, and it turned out he had a 8.5" housing. we never expected it at all, but a very welcome surprise of course. My ex-father-in-law has a 1998 s-10 SS (yes a real B4U optioned truck) that he ordered with an automatic and a posi, and he has a 3.42:1 gear and a 7 5/8" rear end. The CAR that I got my 8.5" posi out of for my Caprice was an olds, and when I was researching the ring gear size it DID have an option code for the 8.5" ring gear, it was GM8, but IDK if that is a valid code for the ST trucks.
EDIT......Hey Jigg, is that 8.5" G80 out of a 2-door or a 4-door? If it comes with a manual only, it's have to be a 2-door of course, but aren't they different lengths? IIRC, the 4-door's rear axle housing is a couple inches wider?
