What's it worth?
Old Nov 20, 2019 | 06:03 PM
Blazin_Alexei's Avatar
Blazin_Alexei is on a distinguished road
Default What's it worth?
Well ive had it with my blazer and im probably going to part ways. Wondering what everyone thinks i should try and get for it. Located around orlando
2001 chevy blazer 4 door 2wd 209k miles
the bad
Runs rough at idle, seems to have some internal engine problem leaks/consumes tons of oil
bad control arm bushings,tie rods,idler arm, ball joints,
Leaky power steering pump and gearbox
Has rust on roof
No heat, no AC(needs heater core and ac condensor)
4l60e going bad(very bad fluid, slips, no tc lockup)
Needs radiator, and paint is kinda rough
the good
New intake and upper engine gaskets, billet distributor, accel coil, msd wires, delco iridiums, new 02 sensors, mpfi injectors, new rear main seal, oil pump, oil pan gasket,fuel pump, etc
Ported and polished intake, throttle body, maf, cold air intake, high flow exhaust
all engine hoses, and all fluids are new
3 inch lift on 32" mud terrains, black rock 15x11s
Zr2 rear axle swap with heavy duty springs
Very nice trailblazer interior
Comes with everything to swap to nv3500 manual transmission
Optima red top
rear mount tire carrier
performance rear brakes
and plenty of other parts
Opinions appreciated
Old Nov 20, 2019 | 06:08 PM
Cimmerian's Avatar
Sounds like a mechanic special, honestly. The ingredients are there for a solid ride but it sounds like the engine and trans gotta be replaced or rebuilt and that is going to easily cost more than the actual worth of the truck. I mean, it runs so there's that.
If you part it out, I'd be interested particularly in the rear tire carrier and the tailgate glass hinges and door panels.
Old Nov 20, 2019 | 08:07 PM
Thats kinda what i was thinking, still a daily driver but a sketchy one. I already have the Trans but motor at least needs a top end rebuild. I would finish it but it just seems to break more every time i touch it. Will let u know if i part it out
Old Nov 20, 2019 | 08:11 PM
Cimmerian's Avatar
Let me know. I can probably pick up those items from Orlando next week since I'm moving if you do.
Fozzy
Aug 18, 2019 11:03 PM
hylander6361
15
Oct 31, 2015 06:04 PM
BirchyBoy
17
Feb 28, 2015 10:52 PM
ZR2Winnebago
Dec 22, 2013 09:07 AM
Chevy33
Jan 7, 2012 06:19 PM
