where can i get replacement Distributor Cap screws?
Old Nov 9, 2012 | 03:23 AM
Antbankz's Avatar
Antbankz is on a distinguished road
Default where can i get replacement Distributor Cap screws?
i lost one of the hardware screws for the Distributor Cap, i believe its a torq screw(star shaped) either t-15 or t-20 (can someone confirm?) anyway where can i get a replacement screw or can i match it at hardware store?
no auto parts stores sell it by itself...and i dont feel like purchasing a new cap for $25-35 just for the screw considering the one i have is less than a year old.
Old Nov 9, 2012 | 06:12 AM
4X4GS10B's Avatar
4X4GS10B is on a distinguished road
Junk yard?
Old Nov 9, 2012 | 06:13 AM
4X4GS10B's Avatar
most rotor buttons come with replacement screws for it and the distributor cap and it's a lot cheaper than buying the cap
Old Nov 9, 2012 | 06:51 AM
mmmrodge's Avatar
mmmrodge is on a distinguished road
x2 bone yard
Old Nov 9, 2012 | 12:53 PM
Antbankz's Avatar
rotors screws are slightly smaller (t-15)
thanks guys i will hit up my local pick a part this weekend and hopefully get lucky, on a side note.. found a video from 1aAuto and it is a t-20 bit
Old Apr 2, 2019 | 05:13 AM
dbelcourt's Avatar
dbelcourt is on a distinguished road
Hi, I got the cap and rotor off my 1995 Blazer. It was a royal PIA, can't belive they come up with this design. I've got new ACDelco parts on order and should get them by end of week.
I looked at a few YouTube and it's obvious that the intake is better suited on later years. On this 95, there is no way to get any common torx driver/adapter. Part of the intake covers the engine side cap screw and 1/4" extension can't clear.
I'm thinking if I replace the screw(s) with a Phillips head I'll be able to slip a skinny screwdriver or bend one to fit. Alternatively a more common hex/Allen might also work. Anyone else tried this on a 95? I don't think I'll be able to reinstall the T20's the way I got them out.
I missed the days when caps were held with spring loaded hooks and a 1/4 turn with a flat head was all it took. :-(
Old Apr 2, 2019 | 08:29 AM
eshaw's Avatar
I had a 95. You can get drivers with flexible shafts that look like a wound spring. They work well for stuff like this.
Old Apr 3, 2019 | 08:36 PM
dbelcourt's Avatar
Smile
Thanks for the suggestion. I didn't think that would fit either. I'll pick one up and try it. Still hate torx screws!
Old Apr 5, 2019 | 06:37 PM
Wyldmyn's Avatar
Wyldmyn is on a distinguished road
I have a 95 Blazer and to get the torx out front closest to fire wall I use a 1/4 inch torx head with the 2inch extension and ratchet. It's easier to leave the ratchet off then u get some room to get to the torx head.
Old Apr 5, 2019 | 09:22 PM
Trukntigger's Avatar
Cheap set of wobble extensions works wonders.
gidgigoo17
Jun 22, 2015 06:04 PM
Krafty10
Apr 11, 2015 08:03 PM
LannyL81
14
Mar 4, 2013 05:21 PM
1gmctruckman
16
Jan 15, 2013 03:51 PM
sdaringer
Jul 25, 2012 09:02 PM
