Wipers Move Backwards
Old Nov 1, 2012 | 03:58 PM
xgiovannix12's Avatar
sounds like the wiper arms need to be moved.... That means removing them off the splines and replacing them in the correct spot.
Old Nov 1, 2012 | 04:52 PM
^^^ X2
Remove the arms, turn the ignition on, turn the wipers on, then off, wait for them to park, turn the ignition off and install the arms.
Old Nov 1, 2012 | 05:49 PM
zball94's Avatar
zball94 is an unknown quantity at this point
This will only change the parking position, not the direction of the wipers.
Old Nov 1, 2012 | 06:02 PM
not if done right... IF you set the motor into park position and then install the wipers like captain stated. They should be adjusted properly after that.
Old Nov 2, 2012 | 12:14 AM
richphotos's Avatar
I agree with what Gio and captain are saying, take the wiper arms off, put the motor into parking postiion (off) and then put the arms back on, should fix the problem.
Old Nov 2, 2012 | 12:31 AM
zball94's Avatar
Turns out the problem was actually how the wiper mechanism is mounted onto the motor. I think I had them running when I pulled the negative battery terminal, causing them to stop mid-stroke (the arms were off so I didn't notice), so I figured this was the actual neutral position. I feel dumb now
Old Nov 2, 2012 | 12:33 AM
glad its all fixed man....
atvwarrior
Performance & Brainstorming
May 19, 2012 09:20 PM
rustynutz
Dec 14, 2011 01:16 PM
Jonas
Aug 9, 2010 06:29 PM
1979K5
May 4, 2010 09:33 AM
bodhifirestarr
Mar 28, 2009 04:27 PM
