WOOT hit the big 200k
Old Apr 20, 2008 | 02:52 AM
wesmagyar's Avatar
wesmagyar is an unknown quantity at this point
Default WOOT hit the big 200k
heh and the check engine light is due to my EGR valve it really only kicks in when i go over 45 mph. wierd huh?
and uh... i kinda gotta clean the truck.
-Wes-
ps. i took these while driving (heh yeah i know im a bad man...) i was actually recording it with the camera's video capture mode but the batteries died just before it flipped. so i pulled over and put another pair in and they died too... so i swapped em around and was able to get these 2 photos off before they died for good.
Old Apr 20, 2008 | 07:33 AM
noom14921992's Avatar
noom14921992 is an unknown quantity at this point
Default RE: WOOT hit the big 200k
wow do you have any advice for my 183000 mile 2 gen. blazer for perts and service to keep it runing good so i can keep it for a long time. by the way i replaced my "egr" valve on my 1st gen. and it cost me $300.
Old Apr 20, 2008 | 11:53 AM
wesmagyar's Avatar
wow you got ripped off pretty hard. ive been able to find mechanics that will do it for a little over a hundred and that includes the cost of the part. its about an hours labor and the part costs 50 bucks at an autoparts store..
as for advice use good oil keep it changed on a regular basis at least every 3k miles or so. um change the spark plugs every so often. dont floor it every chance you get. baby it. all in all just take good care of it.
-Wes-
Old Apr 20, 2008 | 11:07 PM
Onimun's Avatar
Onimun is an unknown quantity at this point
Welcome to the club!
Old Apr 21, 2008 | 11:45 AM
mr.vls's Avatar
What is with the High Oil Pressure Reading? The needle looks pegged. Congrats on 200K. I am pushng 390K but the engine/trans have both been replaced with GM factory rebuilts.
The reason I mention the high oil gage pressure is that I had the same thing on my car and it turned out that the PCV port on the TBI was plugged with carbon/oil deposits and once I cleaned the TBI unit the oil pressure returned to normal. Replaceing the PCV did not correct the problem either. The bottom line is that i did not have a functioning PCV system due to a plugged Throttle Body Port.
Old Apr 21, 2008 | 12:45 PM
wesmagyar's Avatar
huh... i asked my mechanic about the oil pressure reading so high he said that that wasnt problem. he said it would be a problem if it was low but high no big deal. as for the pcv being plugged i had that changed when i got it... and it also wouldnt surprise me if there are carbon problems as my EGR valve has been broken for at least 7-8 thousand miles worth of driving. i really need to get that fixed but i dont know how to do it and mechanics will rip you off now a days...
-Wes-
ps as for the typo's i just woke up... sorry ill edit this later and fix it
Old Apr 21, 2008 | 01:50 PM
FirehawkNS's Avatar
FirehawkNS is an unknown quantity at this point
Nice. I have a buddy that has crossed over 240k on their 96 with the intake gasket being the worse thing that has happened to it.
Old Apr 21, 2008 | 06:22 PM
thegr81's Avatar
Congrats on reaching the 200k mark!!! I have a long way to go before i hit that in my blaze!!!
Old Apr 21, 2008 | 07:58 PM
mr.vls's Avatar
When my oil gage was registering high pressure like yours indicates I was also blowing oil out of the dipstick tube if the dipstick was not fully seated, also the PCV valve would pop out of the valve cover. So I was having issues due to a lack of crankcase ventilation. If you are not having any of these issues you are probaly ok. My next milestone will be 400k sometime this year! But there is hardly anything mechanical that has not been replaced over the years.All of my weatherstripping has been replaced, the car has been repainted, all bushings and motor mounts, engine and transmission. The last thing I did was to replace the rear leaf spring and shackle bushings. That was a real PIA. I was able to accomplish the leaf spring bushings but I had to have a shop replace the rear schackle bushing as I had no way of getting at them the shop had to drop the gas tank and use combination of a ball joint press and brute force to press the old ones out.
step66
Feb 21, 2013 01:33 AM
Hanr3
Jun 12, 2011 12:04 PM
matt6387
Jan 2, 2011 03:58 PM
stlwaco
Nov 13, 2010 08:55 PM
elementalnature
Dec 24, 2008 09:47 AM
