ZR2 Suspensions
Old Jul 30, 2020 | 11:33 PM
Xracing1's Avatar
Xracing1 is on a distinguished road
Default ZR2 Suspensions
So if the ZR2’s are 2 inches higher then the non ZR2’s and the rear springs are how Chevy lifted the rear how was the front lifted? Torsion bars keys? Question 2 the ZR2 is 4ish inches wider how was the front made wider? Wheels? Thanks in advance.
Old Jul 31, 2020 | 06:00 AM
The mounting locations for the rear leafs where extended, the front mounting for the control arms are in different locations, and control arms are bigger.
I believe lol.
Old Jul 31, 2020 | 11:04 AM
El_Beautor's Avatar
Like DonL said, The ZR2 frame is different. The front hanger on the rear leaf is much larger putting the spring pack lower, and the front control arm locations are lower on the frame, and have bump-out spacers to make the truck wider. I believe the leaf spring packs are the same length, but the eyes on the end are slightly different and there may be a difference where the pin hole is on the ZR2 vs non-ZR2.
I'll disagree with DonL on one point though, in that I'm 99% sure that the only difference between the control arms is the sway bar mount, which is for sure different between the ZR2 and non-ZR2. I'm almost certain that both the upper and the lower arms are the same length and geometry.
Old Jul 31, 2020 | 11:37 AM
Thanks for clarifying. Wasnt sure about the front.
Old Aug 1, 2020 | 12:48 AM
Xracing1's Avatar
Thank you both for the info I am converting a ZR2 to 2wd and LS swaping the blazer was just trying to understand what the difference was. Thank you both again
Old Aug 1, 2020 | 08:04 AM
Going from 4x4 to 2wd? Any specific reason?
will you br posting a built thread? I'm interested.
Old Aug 1, 2020 | 07:25 PM
Xracing1's Avatar
I Always wanted a 2dr 2wd blazer and I got this one with a blown engine for $200.00 And so that started it.
I will do a build thread I guess most people don’t seem to have much of a sense of humor about going 4wd to 2wd, I’ve gotten allot of slack about it on other forums but its mine and no one is paying for it but me so what The hell. Lol
Old Aug 2, 2020 | 11:47 AM
That's just it!
papacope
Jan 28, 2010 06:21 PM
Spectreblazer
Suspension Tech
26
Jan 13, 2010 09:33 PM
vermillion2
Lifting Tech
Aug 4, 2009 09:22 PM
Logan
Lifting Tech
Sep 18, 2008 11:44 AM
jessesjimmy
Suspension Tech
Mar 3, 2007 03:14 PM
