General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
"!POP!"
Old Oct 20, 2006 | 02:08 AM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Default "!POP!"
When my suspension flexes, even on a tiny incline (in town driving or off-road) the front end makes a loud !POP!. It only does it when the wheel is turned though. . . It sounds like it is coming from my left front wheel well..... what could make this noise happen?
Old Oct 20, 2006 | 02:12 AM
Chevy Lover's Avatar
Default RE: "!POP!"
Hmm, sway bar bushing, link pins, c/v joints, control arm bushings or ball joints.
Check the link pins at the end of the sway bar first, then check for oil on the sway bar bushings.
Old Oct 20, 2006 | 02:19 AM
a_tack's Avatar
Default RE: "!POP!"
I don't know if this would help troubleshoot... but I can't seem to get it to make the noise in 4 wheel drive..... only in 2wd.... weird huh?
Old Oct 20, 2006 | 04:27 AM
Default RE: "!POP!"
Hmmmm.......gonna have to sleep on that...c/v joint or loose front diff mounting bolts?
Wxman2000
Aug 11, 2007 03:48 PM
ShadowHawk
Suspension Tech
Feb 11, 2007 09:50 AM
cimbali
Jun 30, 2006 05:07 PM
knuckles
May 22, 2006 02:11 AM
Rwolf
Feb 13, 2006 01:46 AM
