General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
1995 blazer fuel regulator
Old Jul 18, 2006 | 11:32 PM
blazer951200's Avatar
blazer951200 is an unknown quantity at this point
Default 1995 blazer fuel regulator
Anybody replaced the fuel regulator in a cmfi unit? I found an aftermarket regulator sold by 1AAUTO.COM and others. They say it can be replaced separately from the injection unit. Part #PLP2560000 on their website. Any info would be much appreciated as this is the third time mine has failed and spending another 300 dollars for the new unit would suck.
Old Jul 18, 2006 | 11:59 PM
Default RE: 1995 blazer fuel regulator
If the CPI spyder is anything like the CSFI spyder in the mid'96+, the FPR is held in by a snap ring and sealed with an o-ring. Should be able to replace it without replacing the whole CPI spyder. It mostlikely will require the removal of the spyder from the lower intake and if that is the case, I would advise replacing the 'nut kit' which consists of the internal feed/return fuel lines to the spyder. They really are only meant to be used once and often leak if reused.
Have you removed your upper intake and pressurized the fuel system? You can do this to verify that the FPR is where it actually is leaking. If you have replaced the CPI spyder before without replacing the 'nut kit', it is quite possible that the problem was leaking internal fuel lines, not a leaking FPR. Just a thought.
Old Jul 19, 2006 | 12:33 AM
Replaced the nut kit last time. I believe the 96 is a different injector unit. From what I have heard the regulator can't be replaced on the "w"code engine but this company says it can.
Old Jul 19, 2006 | 12:33 PM
Here's something that I found with a google search:
http://www.lindertech.com/4~3_regulator_adapter_kit.pdf
But from the pictures and descriptions I have seen/read, it looks like the FPR is held in by a plate that gets screwed fast to the CPI spyder body.
Old Jul 20, 2006 | 06:31 PM
AdamCoop's Avatar
AdamCoop is an unknown quantity at this point
Just replaced mine on my Blazer yesterday. Mine is a "w" as well. It was a very simple fix as well.
Coope
Old Jul 21, 2006 | 10:43 PM
Adamcoop, did you use the lindertech regulator or?
Terje
Nov 4, 2017 08:19 AM
swartlkk
39
Feb 20, 2010 09:39 PM
phillymick
Nov 9, 2008 07:54 PM
jlinder
Aug 21, 2005 11:08 AM
