General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
1997 blazer LT
Old Jun 5, 2006 | 09:39 PM
Canadianblazer97's Avatar
Canadianblazer97 is an unknown quantity at this point
Default 1997 blazer LT
I just bought a 97 LT.
There was a squeak in the belt and i got it replaced took the noise away for a day and now its back. seems like it is from the tensioner but im not too sure. Just wondering if anyone else has had this problem
I am also having an issue with my brakes. They squeal like a ****. i have no idea what the problem is.
Im a former hondaboy so i know nothing about Chevs. so any help would be great.
Old Jun 6, 2006 | 10:56 AM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
Default RE: 1997 blazer LT
Ok as for the tensioner, I had that problem. Take the belt off and get a very low grade sandpaper and just scuff it up slightly. This will take away THAT noise, drove me nuts till I did that. Its like it got too smooth or something!
As for the brakes, they might just be cheap brakes that were installed. I had that trouble too. Is there a LOT of brake dust?? Also might want to check to see how much wear they have. The pads have little tabs on them that squeals when they get too low, even when your foot is NOT on the brakes!
Hope that helps ya... Let me know.
Old Jun 6, 2006 | 02:26 PM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
sometimes the really long lasting brake pads are such a hard compound that they squeek also. I had them, they lasted two years instead of one, but they were annoying. As Dory said, cheap brake pads can do the same thing. Try pulling the wheels off, there might be a buildup of brake dust you can clean out.
Old Jun 7, 2006 | 03:59 AM
ok im not familiar with a V6, the tensioner on it is on the bottom left corner right?
the pulley right in the top middle of the belt seems kinda squeaky too.
Old Jun 7, 2006 | 10:27 AM
Dory's Avatar
The one in the top middle is the one I was referring to. I hope that it helps ya.
Old Jun 9, 2006 | 11:04 PM
ok i took it in and they said that the bottom seal on my water pump is dry and causing the creaking. I asked them to put a new seal in and they said that you cant, you have to buy a whole new water pump. does that sound right? cause it doesnt to me.
Old Jun 9, 2006 | 11:32 PM
tomsblazer's Avatar
tomsblazer is an unknown quantity at this point
Water pumps are an expensive replacement if the shop does it. I have had a few go bad and by that i mean that I replaced them only after they start leaking water.
If it is cooling properly, I'd just live with the noise a while.
Old Jun 9, 2006 | 11:39 PM
Waterpumps are not servicable, they are just replaced. You could try to spray it down with wd40 or another rubber softening agent, but it may make the waterpump leak.
Old Jun 13, 2006 | 03:36 AM
tjbmmb's Avatar
tjbmmb is an unknown quantity at this point
Just had my waterpump done on my 98 Blazer, Did it at sears only cost $80 bucks, 40 for the part and 40 for the labor, but i work in the auto center as a tech/salesman so i did get the part at cost.
hlaverty06
Mar 23, 2014 09:25 AM
jbw23
Sep 5, 2012 08:56 PM
vtlew
Jun 23, 2006 09:13 PM
polcat1998
Mar 1, 2006 06:05 PM
reggie4828
Engine & Internal
Jan 6, 2005 10:58 PM
