General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
2001 chevy blazer 4wd
Old Oct 2, 2006 | 10:31 AM
rek302005's Avatar
rek302005 is an unknown quantity at this point
Default 2001 chevy blazer 4wd
my check engine light came on, so i went to auto zone for them to pull the codes and tell me whats wrong. it was sluggish and occasionally would just stall. the results of the code was..."low voltage to the o2 sensors" grrrrrrrr please tell me what that means.. is it the actual sensors or the wiring or what.
Old Oct 2, 2006 | 11:02 AM
Blasir's Avatar
Banned
Blasir is an unknown quantity at this point
Default RE: 2001 chevy blazer 4wd
Check your battery terminals. My Blazer had that code when I bought it with the SES light on 3 years ago. Turned out to be weak connection at the battery terminal. I replaced the 2 nut/connector inserts and cleaned the battery and voila, that was it!
Old Oct 2, 2006 | 10:44 PM
Chevy Lover's Avatar
so what was the actual code # ?
Old Oct 2, 2006 | 10:51 PM
Brian J. Lesko's Avatar
Brian J. Lesko is an unknown quantity at this point
As Chevy Lover said, did they give you an actual code number? Should be POxxx. If you have that you can look up the code to get a better idea of what's wrong.
hlaverty06
Mar 5, 2014 07:14 PM
ChevyMane808
Apr 5, 2013 10:51 AM
kyle123
Apr 4, 2010 02:27 PM
mojo
Dec 6, 2006 01:48 AM
beeneeb
Dec 7, 2004 05:10 AM
