General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
4 Wheel Drive does not work. Help!!!
Old Oct 18, 2006 | 11:58 AM
huskerman18's Avatar
huskerman18 is an unknown quantity at this point
Default 4 Wheel Drive does not work. Help!!!
Ok so I drive a 1986 Chevy Blazer s-10, 2.8L V6, 4wd.
My problem is that the 4 wheel drive shifts into gear but the front wheels will not engage. I found this out on a really slick snow packed hill in Tahoe and ended up going down the hill backwards against my will!!! In any case I 1 would like to know if this Blazer was supposed to have locking hubs (the previous owner changed the rims and there are now no locking hubs) and if it is where can I get some. 2 If it is not the hubs then what else could it be and is it a cheap fix??
any help would be appreciated
Aaron
Old Oct 18, 2006 | 12:16 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: 4 Wheel Drive does not work. Help!!!
welcome to the forum. no ...no locking hubs are available. There is a vacuum switch on top of the t-case that routes engine vacuum to the front axle actuator...under or neer the battery....which pulls a cable to engauge the front axle ...check all vacuum lines and the cable and actuator.
Old Oct 19, 2006 | 12:45 PM
blzrgrl's Avatar
blzrgrl is an unknown quantity at this point
When my 4 wheel driver wouldn't work it turned out to be a loose wire in my transfer case.
Old Oct 19, 2006 | 01:02 PM
Chevy Lover's Avatar
DO you hear a "click" near the front diff when you shift to 4wd?
It's like Lastcoupe said, there is a vacuum switch on the transfer case that directs vacuum to a servo under the battery tray. The servo pulls a cable to engage the axles at the right side of the front diff. You should be able to hear it engage.
Usually it's a loose vacuum hose at the servo....
TrainChaser22
Dec 4, 2019 12:27 PM
mirrorimij
Jun 8, 2019 03:34 PM
Amelia23
Sep 29, 2012 05:31 PM
lizzj70
Jun 23, 2010 06:57 PM
nai0013
Mar 20, 2007 09:27 AM
