General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
4x4?
Old Jul 27, 2006 | 09:49 PM
bigpar Blazin's Avatar
bigpar Blazin is an unknown quantity at this point
Default 4x4?
This is my first 4x4 but I have no manual or anything. I got those push button ones but am totally clueless on how to use it, I did a search and didnt see anykinda walkthrough. but I was just wondering if you guys could give me a quick rundown Id rreally appreciate it. I just hope it works, although the service 4x4 is not on I just cant tell if it works or not.
Old Jul 27, 2006 | 10:39 PM
Chevy Lover's Avatar
Default RE: 4x4?
here's some reading for you
Mode Shifts
The mode shifts are shifts from 2HI to 4HI and 4HI to 2HI. A mode shift can be accomplished in any gear position and at any vehicle speed. If the system is in 2HI, the driver can shift into 4HI merely by pressing the 4HI shift select button. The 4HI button will blink status whenever a 2HI or 4HI shift is initiated and will continue to blink until the TCCM completes the shift. After the shift into 4HI is accomplished, the 4HI status lamp remains lit to indicate that the system is in 4HI.
There is a difference between when the TCCM sends voltage signals in order to engage a four wheel drive shift and when the vehicle is truly in four wheel drive. The transfer case can be shifted into 4HI and the front axle may not be engaged.
The driver can shift from 4HI back to 2HI by pressing the 2HI shift select button. The 2HI shift select button blinks until the shift to 2HI is complete. The 2HI shift select button will remain on once the shift is mechanically complete.
Range Shifts
The range shifts are the shifts between the HI and the LO ranges.
- 2HI to 4LO
- 4HI to 4LO
- 4LO to 4HI
- 4LO to 2HI
A range shift can only be made with the automatic transmission in neutral or with the manual transmission clutch fully depressed. The shift occurs when the vehicle speed is below three miles per hour. Whenever a shift into 4LO is initiated, the 4LO shift select button blinks. The 4LO shift select button will continue to blink until the shift is completed mechanically or until 30 seconds elapses. The 4LO shift select button must be on and not blinking prior to shifting the transmission into gear or releasing the clutch pedal.
If a range shift is initiated when the transmission is engaged or the vehicle speed is above 3 mph, the 4LO shift select button will blink for 30 seconds and no range shift actually occurs, the TCCM will default and position the transfer case into 4HI.
hope this covers it for you. Enjoy
Manteray
Oct 2, 2011 11:53 AM
razman
Feb 22, 2009 01:57 PM
sfesenko
Nov 30, 2008 08:55 PM
sdm1234
Jan 2, 2008 12:12 AM
tolleyc
Jul 29, 2007 05:57 PM
