95 blazer a/c stops blowing through upper vents when I accelerate
There is a vacuum reservoir on the passenger side under the hood. Typically it's a black ball type thing with vacuum lines into it. They leak frequently. Also, if there has been ANY other work done on the car, vacuum lines can get disconnected and not put back in place. Finding the leak is a difficult job sometimes.... so you will need a little luck, but that's all it is.
Hope this helps!
Hope this helps!
I checked most of the vacuum lines. The upper vents work only if I place the control to bi level A/C. Will sporatically work when placed in the maxi A/C position.
JDHD
May 12, 2021 05:01 PM
djsgarrett
Jul 8, 2015 04:30 PM
msfan324
Oct 19, 2012 02:27 PM
dunontme
Sep 22, 2008 09:49 AM
