General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
98 S10 Blazer - Trunk/Liftgate Release Relay
Old Nov 14, 2006 | 09:13 PM
yeags's Avatar
yeags is an unknown quantity at this point
Default 98 S10 Blazer - Trunk/Liftgate Release Relay
Can anyone tell me which relay this is? I can't find it labeled anywhere.
Old Nov 16, 2006 | 12:12 AM
yeags's Avatar
Default RE: 98 S10 Blazer - Trunk/Liftgate Release Relay
Perhaps I should clarify this post...
I have a 4 door 98 S10 Blazer, and the rear glass does not open by the switch on the dash, the button on the liftgate, or by the button on the remote. I am also unable to turn the key in the back lock on the liftgate, although the door handle on the liftgate does work fully. I pulled the back trim panel off since I saw numerous other posts regarding the "cheap plastic piece" that connects the actuator to the release lever. This piece is fully in tact, and the actuator does not appear to be frozen or stuck. I put a multi meter on the power connector that goes into the actuator, and it does not show any voltage. I assumed this meant that there is either a short in the line somewhere (there are no blown fuses), or a bad relay. Problem is... I can find a part listed as a "Rear liftgate Relay" that is available, but I can not find any listings of where that relay might be located. Can anyone help me with this one?
Rael
Feb 17, 2013 12:18 PM
ejwilson1984
Apr 11, 2012 09:46 AM
encrypted
May 31, 2011 09:45 AM
Inferno
Jan 21, 2011 11:56 AM
Ugly_Monkey
Mar 18, 2009 12:42 AM
