General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
99 Blazer 2WD problem
Old Oct 24, 2006 | 07:17 PM
tercanb's Avatar
tercanb is an unknown quantity at this point
Default 99 Blazer 2WD problem
I have a 99 Blazer with Autotrac 4 x 4 (four buttons). In 2WD, I am able to only go a few yards and the Blazer starts making a growling, grinding sound and it is hard to steer or drive. I have checked and replaced the front differential fluid. I replaced the right half shaft (inner CV joint was leaking), upper and lower ball joints, replaced transmission fluid and filter. When I try to go into Auto4WD or 4WD, the light just blinks and then goes back to 2WD. What should I check next?
Old Oct 24, 2006 | 08:44 PM
chucknienhuis's Avatar
chucknienhuis is an unknown quantity at this point
Default RE: 99 Blazer 2WD problem
same tires all the way around?
Old Oct 24, 2006 | 09:20 PM
tercanb's Avatar
Yes, same tires.
Darren Spevak
Lowering Tech
Aug 29, 2011 12:33 AM
friedaddy
Apr 25, 2011 11:22 AM
dbaas
Oct 20, 2010 07:27 PM
TheBadGuy
Jan 3, 2008 10:59 AM
nine5blazer
Oct 18, 2005 05:19 AM
