General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
99 zr2 wont go in 4x4
Old Nov 10, 2006 | 02:10 PM
chrissy's Avatar
chrissy is an unknown quantity at this point
Default 99 zr2 wont go in 4x4
i have 99 zr2 and wont go in 2 4x4 all it does is flash in 4 hi and makes a clunk when goes in 2 4 lo changed the shift motor at a cost of 1200 bucks and still not workin . any idea on what is going on with it could it be the switch itself or what
Old Nov 11, 2006 | 02:49 AM
slammins15's Avatar
slammins15 is an unknown quantity at this point
Default RE: 99 zr2 wont go in 4x4
x
Old Nov 11, 2006 | 10:50 PM
Chevy Lover's Avatar
Have you tried to check for codes?
Turn OFF the ignition for 10 seconds.
Connect PIN 13 on the data link cable (DLC) to a ground. The DLC is located in the cab under the instrument panel on the driver's side.
Turn ON the ignition, with the engine OFF.
Observe the transfer case shift control switch select buttons for flashing codes
All the bottons should flash together to show a code.
There are 4 possible codes, 1,2,3 or 4.
Bberry20
Feb 25, 2010 09:28 PM
Spectreblazer
Feb 13, 2010 04:59 PM
Logan
36
Dec 6, 2009 07:41 PM
PJT2007
Oct 7, 2008 10:47 PM
Logan
Lifting Tech
Sep 18, 2008 11:44 AM
