General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
A/C compressor
Old Jul 3, 2006 | 07:19 PM
p_j_robertson's Avatar
p_j_robertson is an unknown quantity at this point
Default A/C compressor
How do you know if your A/C compressor is bad. My engine still runs but under the hood when you turn on the A/C every 5 seconds it turns for about 2 then shuts off again. Is it supposed to keep running or on off like that? No it is not blowing cold air in the least.
Old Jul 3, 2006 | 08:42 PM
ELTZY's Avatar
ELTZY is an unknown quantity at this point
Default RE: A/C compressor
low freion. get a recharg kit
Old Jul 3, 2006 | 09:40 PM
Chevy Lover's Avatar
I agree, low on refrigerant. Low because it's leaking.
Look for oil leaks at the front of the compressor, at the connections (both ends) of the high and low pressure lines at the accumulator and condensor.
Old Jul 5, 2006 | 04:02 AM
Annekat91's Avatar
Annekat91 is an unknown quantity at this point
To answer your question, yes it is supposed to come on and turn off, not run continuously, but it's not supposed to do it as often as yours is. I'm not sure the correct interval, maybe 15 seconds or so, from what I've heard. Mine does the same thing, but I'm still getting some cold air. I was told by my mechanic that it is low freon, and might just need a recharge or might need more extensive work. I'm curious about the recharge kit mentioned in one reply, how cheap and easy it is to use, etc., since the price quoted by the mechanic for a recharge was kind of a lot.
Anne
'91 S-10 Blazer, 2dr, 4.3L, 4X4
151,000 miles
Old Jul 7, 2006 | 10:39 AM
I bought a recharge kit at the shop for $13.45 a can so not too expensive. Don't know if it works yet Blazer in the shop for clutch work.
gmcjimmy_94
Dec 30, 2010 12:37 AM
bcw757
Jul 3, 2006 08:44 PM
SniperX13
Jun 4, 2006 02:59 PM
NJEMT
Jun 1, 2006 01:40 AM
tammikm
Oct 28, 2005 12:15 AM
