General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
clunking in front end when you turn the wheels
Old Sep 10, 2006 | 10:36 PM
melissa97blazer's Avatar
melissa97blazer is an unknown quantity at this point
Default clunking in front end when you turn the wheels
there is a clunking coming from the front end when you turn the wheels. while your driving it also sounds like there is a grinding noise. we have replaced both the left and right wheel bearings as directed by a mechanic. the left works fine. we have replaced the right twice and are now going for a third time. does anyone have any idea what could be doing this?
Old Sep 10, 2006 | 10:42 PM
Jman's Avatar
Jman is an unknown quantity at this point
Default RE: clunking in front end when you turn the wheels
I had the same problem. I replaced the Idler arm yesturday and my clunking is all gone. I still got to change the Pitman Arm. Have those checked out, and maybe check out your Balljoints and Tie-rods aswell.
How often are you changeing them bearings?
Old Sep 10, 2006 | 10:51 PM
well i have only had the car about 2 - 3 years. this is the first time im changing them. i don't know the history about the wheel bearing with the previous owner.
Old Sep 10, 2006 | 11:03 PM
Jman's Avatar
Alot of the time the grinding noise is just a build up of corrossion on the brake drums and rotors
Old Sep 11, 2006 | 01:51 PM
hmmm. well as i write this the other wheel bearing is being put on to see if maybe the others were defective. but we will see. ill keep in mind what you have said. if this doesn't work, im just going to break down and take it to a shop. i want to be able to drive my car. i miss it.
Old Sep 11, 2006 | 02:06 PM
ok, so the other wheel bearing is on and the clunking is gone. Im so happy! so apparently what it was is that the wheel bearings we bought from Advanced Auto Parts were defective. so we bought this last on from NAPA and it works just fine. thanks for all your input.
Old Sep 11, 2006 | 02:39 PM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
ORIGINAL: melissa97blazer
Must be 2wd model....There is a lifetime warranty on the 4x4 bearing/hub assembly.
Old Sep 12, 2006 | 07:21 AM
Aquahallic's Avatar
Aquahallic is an unknown quantity at this point
lifetime warranty???
Is this from GM?
Old Sep 12, 2006 | 09:27 AM
ORIGINAL: Aquahallic
Is this from GM?
ROFL, GM hardly honor thieir 3 year warranties let alone lifetime, But no, its not GM stamped. Doesnt mean anything though except you are getting the SAME part cheaper.
tibby
16
Nov 19, 2015 03:14 PM
blazinnzr2
Oct 26, 2015 04:00 AM
hokieyaker
Jan 26, 2011 01:57 AM
TeamSumner
Jan 19, 2011 01:49 PM
kwsrv@libcom.com
Sep 7, 2005 05:01 AM
