General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
electrical issue
Old Sep 18, 2006 | 05:27 AM
regisvu's Avatar
regisvu is an unknown quantity at this point
Default electrical issue
hi everyone, i recently got a 95 blazer. it has a few electrical issues... i searched around but didnt really find any answers. so here go the questions/problems
-my dome light does not turn off. i removed all the door triggers, including the one in the hath, they still stay on. the dimmer swith dims, but doesnt turn them off. i really dont want to go through all the wiring, so hopefully someone has something for me. the key and light chime work.
-i have power seats, but they dont work(driver and pass). the only fuse box i found was to the right of the driver side. eveything is plugged in. the motors work (i hooked up 12v to see they still worked)
-my gas guage seems to go up when my rpm goes up, and goes down to where it should be when the rpms drop.
Old Sep 18, 2006 | 12:21 PM
fnirish's Avatar
fnirish is an unknown quantity at this point
Default RE: electrical issue
I had the same problem in my 89 IROC convertible. Turned out to be the little thumbwheel switch that regulates how bright or dim the dash lights are. If it isn't that, you're probably just still getting a ground out somewhere in that circuit.
Old Sep 18, 2006 | 01:31 PM
regisvu's Avatar
i didnt try a new dimmer switch, but i unplugged it and the lights still stay on
Old Sep 19, 2006 | 12:15 PM
fnirish's Avatar
You must still be getting a ground somewhere in that circuit. If there has been an aftermarket radio installed or any other work done that would require wire splicing, etc. you could have some other wires touching. If it's like what I've seen, the door triggers have "hot" coming to them all the time, then when the door opens the trigger completes the circuit by grounding to its metal seat in the door frame. So again, it's my guess you still have a ground somewhere. I suspect it could even be somewhere on the lighting which is controlled by the dimmer, which would include the radio. Good luck.
JoSHN
Sep 14, 2012 04:56 PM
zipper_018
May 20, 2007 12:45 AM
Bauer318
Nov 1, 2006 04:06 AM
jdpilot
Oct 24, 2005 04:01 PM
Painkiller1990
Sep 17, 2005 02:34 PM
