General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Fan Push or Pull?
Old Mar 20, 2006 | 09:55 PM
st_pinetree's Avatar
st_pinetree is an unknown quantity at this point
Default Fan Push or Pull?
Hi, New-B here with what is probably a stupid question. Does the fan on a 98 blazer push air out the grill or pull it it in? I just changed out the fan clutch, I'm sure I put the fan on the way it came off, but something just doesn't seem right to me. Thanks in advance.
Old Mar 20, 2006 | 09:59 PM
Default RE: Fan Push or Pull?
Pulls through.
Old Mar 20, 2006 | 10:02 PM
That's what I figured. Is it possible its going backward due to the wrong fan clutch, or did I put the fan on backwards? I was sure I put the fan on the same way it came off. Fan rotates counterclockwise as you're facing the engine correct?
Old Mar 20, 2006 | 10:10 PM
The fan is driven off of the waterpump... So unless you have your serpentine belt on wrong, everything should be fine.
As far as the rotation goes... I'd have to go take a look at mine to see...
Old Mar 20, 2006 | 10:20 PM
4lowlife's Avatar
it rotates clockwise. (you facing the front end.)
Old Mar 21, 2006 | 12:20 AM
Thanks guys. Its all good. I was certain it felt like it was pushing air out the grill, but a little smoke test proves I was just being paranoid!
Old Mar 21, 2006 | 03:27 PM
Hanr3's Avatar
Welcome, and I like your ingenuity to figure it out.
Good job.
Blazers.B.Kewl
Apr 22, 2013 10:06 AM
KevT
Sep 8, 2012 02:05 PM
cheesequaker
Apr 25, 2012 01:44 PM
valeria1782
Jan 24, 2011 04:12 AM
upblazer95
Nov 16, 2008 03:20 AM
