General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Front Diff
Old Aug 4, 2006 | 01:52 PM
Aquahallic's Avatar
Aquahallic is an unknown quantity at this point
Default Front Diff
WHERE on EARTH is the drain for the front diferential on a 95 4wd... I can find one plug but not the other and I don't see anything on the bottom of it....:/
Old Aug 4, 2006 | 04:05 PM
tom1337's Avatar
tom1337 is an unknown quantity at this point
Default RE: Front Diff
Some diferentials do not have drain plugs and you must remove the cover. Some are on the bottom. I have both kinds, the upside on having to remove the cover is that you can inspect the condition.
Old Aug 4, 2006 | 04:08 PM
Aquahallic's Avatar
Mine doesn't have a cover... it's a split case... and when you say "cover" are you talkin' about a cover like what's on the rear??
Old Aug 5, 2006 | 12:10 AM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Rich the drain plug is on the left side below the left front axle, should be a 13mm hex head with a plastic gasket. the fill plug is on the right side of the case half about half way up in front of the right axle extension housing and should be a 15mm hex head with a plastic gasket. It takes 80W90 gear oil and 2 quarts will be more than enough.
Old Aug 5, 2006 | 01:45 AM
Chevy Lover's Avatar
here's a pic that might help
[IMG]local://upfiles/2910/4FFA7D0DAE654475AD6B06411E9BC887.gif[/IMG]
Old Aug 5, 2006 | 09:23 AM
Aquahallic's Avatar
Kewlness,
I'll be under there bleedin' brakes today so. I got a rear diff gasket and gonna replace that too. and I'm gonna do the xfer case...:P
I don't use the dextron **** right? It specs for ATF in the xfer case.
Thx!
Old Aug 5, 2006 | 01:37 PM
ATF in the transfer case and 80/90 in the diffs
dagda
Jan 12, 2010 06:37 PM
ComputerNerdBD
Mar 18, 2009 06:13 PM
stevelknievel
Aug 11, 2007 03:22 PM
Marcin
May 29, 2007 03:17 PM
slayer6x6
Dec 8, 2005 02:24 PM
