General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Fuel Filter Maintenance
Old Oct 1, 2006 | 02:10 AM
Canadian88's Avatar
Canadian88 is an unknown quantity at this point
Default Fuel Filter Maintenance
I have a 2003 2 door Blazer with the 4.3 liter V6, and I want to know how often you need to change the fuel filter. I also need to know where that thing is, and what a good brand is. Can they just be cleaned, or do they have to be replaced?
Old Oct 1, 2006 | 03:00 AM
booblinker's Avatar
booblinker is an unknown quantity at this point
Default RE: Fuel Filter Maintenance
Recomended is like 30k miles, I think. It is on the frame rail. Fram or delco is a good filter. If you have a problem wiht getting crap gas, then you should change it more often.
Brandon
Old Oct 1, 2006 | 10:12 PM
Brian J. Lesko's Avatar
Brian J. Lesko is an unknown quantity at this point
Depends who you ask. I know a mechanic that changes the fuel filters on his vehicles every year. Other people will tell you every 30K or so is good. It depends how much you drive I guess. It's right on the frame rail below the driver side door. Crawl under and you'll see it. It's a metal canister. I don't think that you can clean the fuel filter. It's a sealed unit. They're only around 5 or 10 dollars, so just change it.
chipjumper
15
Dec 14, 2019 08:49 AM
95jblaze
Aug 27, 2011 03:46 PM
edacsac
Feb 12, 2008 05:49 PM
goat6500
Feb 2, 2007 02:58 PM
black19
Feb 1, 2006 11:02 PM
