General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
headlights
Old Mar 9, 2006 | 12:47 AM
blazermom's Avatar
blazermom is an unknown quantity at this point
Default headlights
Hi There ! I hope someone can help me! My 96 blazer has the most annoying problem. My headlights flicker. It only happens when the lo-beams are on. Not when the hi-beams are on or when only the daytime lamps are on. It also goes clickety clickety in the relay box inside the glove box. The lights don't go completely out, but it's almost like a strobe light effect and it's constant when the lo's are on. Another problem is that my lights are not very bright. We've replaced the switch but still have the problems.
The flickering is even worse with the turn signal on.
Old Mar 9, 2006 | 02:04 AM
20Blazer00's Avatar
Default RE: headlights
Check for bad ground wire in the wire harness or check the relay switch it might be weakened from age and not able to stay connected. The relay depends on electromagnetic coils and if the coil is weak then the connection becomes weak...
Old Mar 9, 2006 | 02:10 AM
blazermom's Avatar
thanks alot !! This prob is really annoying.
Old Mar 14, 2006 | 10:50 PM
blazermom's Avatar
Ok, checked relay that was clicking with known good relays and all reacted the same in that spot. Checked bulbs and connections. All ok. Has anyone had any similar problems that replacing the multi-function switch fixed? Don't want to spend hours sorting through wiring to get to something simple. Any kind of input would be helpful and appreciated.
hollywoodgrad
Jan 25, 2012 01:58 PM
AzBlazer
Jul 3, 2005 04:17 PM
FatRyan
Mar 8, 2005 03:27 AM
BlazerSquad93
Feb 17, 2005 11:52 PM
jaleg
Nov 17, 2004 02:53 PM
